Propeller QFN For Sale
in Propeller 1
I've got 130 quantity of the QFN parts for sale. They're still in the tray. I opened the package from DigiKey to see what was inside, but otherwise they're untouched.
DK's best price right now is $7.49 each at that quantity, or $981.19 plus freight for the batch.
Yours for $850. Reply here or via message if interested.
John
John
Do you have the capabilities to place the QFNs?
We can do tqfp backwards and blindfolded, but our in-house qfn yield is patently dreadful. I bought these last fall as the tqfps went world-wide no stock, just to have for emergencies. Figured it'd be easier to respin a circuit board or two than lose 12+ weeks of sales.
Our inventory of the bigger chips has since been replenished with a big buffer. I wouldn't mind making these work, but currently don't have the clock cycles to fine tune a different process. Sadly, we're outside DK's return window at this point.
What are some of the problems you are experiencing with getting them to lay down correctly?
Currently after reflow, we see high and low spots, which means the chip isn't lying flat on the board, and various connections aren't being made.
In the interim, I'd love to hear any tips and tricks people are willing to share.
John
There is info in this thread, including some closeup photos I took.
http://forums.parallax.com/discussion/149285/qfn-chip-solder-points-on-both-bottom-and-edges
Oh, I'm using only QFP now. Fewer layout and assembly headaches!
We've already edited the PCB layout so that the QFN pads extend further out and away from the chip itself.
You mention the part not laying flat on the board and that spawns several questions on my end. Mainly, it implies that you may not be getting full reflow on the solderpaste.
How's your reflow profile look?
What solderpaste are you using?
Are the defects in consistent locations on the QFN? If so, are they near copper pours? (thermal mass)
If you have any defective boards and are willing to ship them to California, I would be happy to x-ray them for you and give your more details as to the exact defect scenario.
-- Texas Instruments: sloa122.pdf QFN Layout Guidelines - Texas Instruments
-- NXP: AN1902.pdf, Assembly Guidelines for QFN (Quad Flat No-lead) and DFN (Dual Flat No-lead) Packages
-- Intersil: tb389.pdf PCB Land Pattern Design and Surface Mount Guidelines for QFN Packages
-- On Semi -- AND8211-D.pdf Board Level Application Notes for DFN and QFN Packages
The CMs I went through this with ended up with good yield after resolving a few initial problems, but I'm sure they were going more by their own experience and industry lore than by perusal of the tech literature.
Another issue with QFNs and DFNs is cleaning. Water soluble solder pastes have relatively high conductivity and it is difficult to clean the excess flux out from the tight QFN or DFN interstices. I became acutely aware of this when testing the conductivity between Prop pins, the same sort of tests I had used with the BASIC Stamp. There was lots of leakage (and by that I mean 10s of megaohms instead of 100s of megaohms). That was solved or improved by a change of flux and by special wetting agents while pressure washing the finished boards, also by decreasing the amount of solder on the center pad. 10s of megaohms don't matter so much in a Propeller circuit, unless maybe it is used for an analog function such as sigma-delta conversion with high impedances. On the other hand, it can be a big issue with analog front end chips, such as a sensitive oscillator or a pH or gas sensor. Those have to be squeaky clean, and it just doesn't make much sense to me to have them in a DFN package. But that is often how they are packaged.
In regards to aqueous flux and QFNs, we only use no-clean processes/solderpastes for BTCs (bottom terminated components) such as BGA, µBGA, QFN, DFN, LGA, etc. As a contract manufacturer, I deal with too many variables between customer designs and component manufacturers to enable a process that guarantees full flux removal under these components, even when we use additives in our wash (such as saponifiers). The cleanest (excuse the pun) way to address the concern is to use no-clean paste. We have also chosen a no-clean paste that can be processed in wash without causing cosmetic issues like hazing, so we able to have assemblies that are processed no-clean in SMT, but TH parts are soldered on selective wave machines with aqueous flux. We use the best tools in each area, so-to-speak.
