Download source code for Guide to Programming Multicore Propeller Microcontroller book
I am trying to download the source code for the book - Programming and Customizing the Multicore Propeller Microcontroller without success. I have gone to the suggested site : ftp://ftp.propeller-chip.com and found the files however I cannot copy them. The best I can do is save them individually as text files and then copy then into the Propeller, rename them and save them as Spin files one at a time. There must be a better way. I cannot find another site that has them for download.
Is there a convenient way to get this source code? I want it to use as I work my way through this book.
Thanks for any help
Will
Thanks for any help
Will
I pasted the link you posted into the windows explorer address box (the files explorer, not internet explorer).
That resulted in 2 folders showing in the file window (PCMProp, and PropC3).
I left clicked on PCMProp, then Chapter_04.
Then I right clicked on the folder "Source", selected copy.
Then opened another explorer window and went to the folder I wanted to copy to (in my case "prop book", right clicked and selected paste. It took about a minute to copy all the files. The folder came over with all the files in "Source" with their correct extensions.
I would guess that you could probably do the same with the PCMProp folder, but I didn't want all the extra folders.
Hope this helps
Tom
Open IE and type the ftp address in the address bar. You should see:
Then hit <ALT> <V> you should see this:
http://forums.parallax.com/discussion/download/117283/FTP_2.jpg
Then you get a normal Windows pane that you can drag and drop files/ directories onto your hard drive:
http://forums.parallax.com/discussion/download/117284/FTP_3.jpg
I've had a lot of problems and frustration lately searching for some early propeller stuff in the forums and finding that the links to other threads/posts just lead to error screens. More recent (but before the forum switch) seems to work ok.
Tom
always learning.........
I am new to Propeller and Parallax so it seems odd to me that they would not make it easier for people to download the open source files. I also have found broken links to what I am searching for.
Thanks again
Will
