Some P2 benchmark results — Parallax Forums
All of these times are using the fastspin compiler (both P1 and P2), so we're comparing apples to apples. The P2 results were obtained on my DE2-115, so using an 80 MHz clock (the same as the P1, which was on a C3 board).
                     P1                      P2
hub fft_bench: 21622192 cycles (270ms)  4324532 cycles (54 ms)
hub fibo(20):  10507664 cycles (131ms)  4053316 cycles (50 ms)
cog fibo(20):   2977168 cycles (37ms)   2276664 cycles (28 ms)
hub xxtea:       116384 cycles            23450 cycles
I think for both xxtea and fft_bench the hardware multiply is making a big difference. Also, of course, hubexec is a lot faster than LMM; we're not seeing as much of a speedup on the COG test. OTOH since Fibonacci is recursive both the P1 and P2 are hitting the stack (in hub) heavily, so they're quite memory bound.
Eric
  • RaymanRayman Posts: 16,013
    Strange that cog fibo is not at least 2x faster on P2.
    Even if the assembly code was exactly the same, P2 only has 2 clocks per instruction where P1 is 4...
    Plus, I'd think the new instructions could make a lot of code faster too...
  • SeairthSeairth Posts: 2,474
    edited 2016-05-09 17:47
    Rayman wrote: »
    I suspect that's due to the branching, which will take 5 clocks each.
    Edit: see later comment.
  • Also, hub accesses occur every 16 cycles on both the P1 and P2, so stack accesses are the same.
    Think branching is 8 cycles on P1. Does the cog fibo need hub access? Thought the name implied was only in cog...
    Rayman wrote: »
    P1: 4 cycles when branching, 8 cycles when not branching
    P2: 4 cycles when branching, 2 cycles when not branching
    Edit: corrected.
  • cgraceycgracey Posts: 14,289
    Seairth wrote: »
    Rayman wrote: »
    P2: 5 cycles when branching, 2 cycles when not branching
    Branches take 4 when taken, 2 when not taken.
  • Rayman wrote: »
    The stack is in hub in both cases, so yes, the cog fibo needs hub access, and I think that's probably the bottleneck.
  • So, does this mean being able to support a stack in LUT would remove significant bottlenecks for a lot of use cases?
    (Runs so as not to suffer the slings and arrows of outrageous comments )
  • Implementing a 16 deep stack in LUT ram
    		wrlut	value,lutsp	'push to lut
    		incmod	lutsp,#15
    		decmod	lutsp,#15	'pop from lut
    		rdlut	value,lutsp
    lutsp		long	0
    For debug purposes you can take advantage of the WC bit to check for
    stack over/under flows.
    		incmod	lutsp,#15 wc
    	if_c	add	stack_overflow,#1
    		decmod	lutsp,#15 wc	'pop from lut
    		rdlut	value,lutsp
    	if_c	add	stack_underflow,#1
    lutsp		long	0
    stack_overflow	long	0
    stack_underflow	long	0
  • Show off!! :D
  • rjo__rjo__ Posts: 2,114
    mindrobots wrote: »
    Show off!! :D
    He is Australian... what do you expect?
