How to do the architecture for this application ? (Arlo)
Hi everybody
My Arlo run now with simpleIde
So I need you're help for this project
I explain
My arlo will start to the point O
with a pushbutton I will select A, B or C (Example B )
Arlo will go to the good place. (B)
Then you will select O, A or C (Exemple C)
Arlo will go to the good place (C)
Can you help me to organise the program?
I thank use functions
function 0
select A
go to A
-- > Return function A
select B
go to B
select C
go to C
-- > Return function C
function A
select O
go to O
-- > Return function O
select B
go to B
select C
go to C
function B
select A
go to A
select O
go to O
select C
go to C
Etc...
I don't know if you understand... and i don't know if it's the best way...
I explain
function 0
select A
go to A
select B
go to B
select C
go to C
function A
select O
go to O
select B
go to B
select C
go to C
function B
select A
go to A
select O
go to O
select C
go to C
Etc...
