Has anyone a project in SPin or ASM for adjustable common RS232 RX Baud rates upto 250K
AndyProp
in Propeller 1
Some example common baud rates used.
300
9600
14400
19200
28800
31250
38400
56000
57600
115200
250000
And any others.
Thanks in advance,
AndyProp
300
9600
14400
19200
28800
31250
38400
56000
57600
115200
250000
And any others.
Thanks in advance,
AndyProp
(calculating baud rate from the transmission its self)? (because the transmission baud may change?)
http://forums.parallax.com/discussion/136720/autobaud-on-the-propeller-not-using-special-characters-but-total-packet-length
If you want to tolerate the widest Baud settings, that's usually AutoBAUD based.
Most commonly something like 0x55 is sent, and timed, and then that used for BIT times.
Because you capture over 8 bits and divide, usually there is spare capture precision (but take care with the rounding details)
A purist might use that extra precision, in the bit-timing, with fractional baud design.
Range and Granularity are the next things to consider :
A P2 at 80MHz will have a SysCLK count of 320 per bit at 250k, and 266667 at 300 Baud, for single-sample designs.
Those are fine enough to give low AutoBAUD errors, without needing fractional baud extras.
Full Duplex can get a little more coarse, as that can use multiple samples per bit, & run both Tx and Rx state engines at the same time.
I am wondering if it exists a object or code to set receive data Baud rates with all of those ranges 300 to 250K.
Not all the same time, just optionally set with something like RXbaud equals 300
300
9600
14400
19200
28800
31250
38400
56000
57600
115200
250000
As I mentioned, there are other drivers there that all use pretty much the same sort of initialization call.
I tend to use fullDuplexSerial4Port because I sometimes need more than one serial port and this only uses one cog for up to 4 serial ports. It also supports hardware handshaking and the timing has been improved since FullDuplexSerial.
Yes, see the comment above that says
All of them are configurable with the Baud rate expressed as an integer.
You need to define the SysCLK, and then usually a single equation sets the Divider(s) from that.
With 32b native support, I would expect all to work as low as 300, and at the very top end, I would suggest you just check the final integer value used, for the timing core.
Values below 100 infer > 1% granularity and values below 50 infer 2% granularity, which is pushing UARTs.
That is what I was looking for
Thank you Mike Green, it is the "fullDuplexSerial4Port" done by "Tracy Allen" ?
obex.parallax.com/object/248
4 ports are very useful indeed
Thank you all and especially jmg for the technical explanation.
