60 Hz Power Frequency Accuracy
tomcrawford
I was wondering how closely a clock that uses the 60 Hz power line would keep time. Of course, over the long run, it is quite good; we all have electric clocks that only need resetting for Daylight Saving and when power failures occur. But what about over the short term (day to day)? Supposing I set a clock to the exact time. How accurate would it be? The wikipedia article says the Western US grid is correct to +/- 2 seconds.
Using a propellor mini, I compared the line to a 1 PPS pulse from a GPS receiver.
I collected data for about 10 days in April 2016. Seven days (Thursday through Wednesday) are shown in the appended graph. The blue line is time of day; the red line is the error. The error does not start at zero because the run was begun a few days before the data starts. It can be seen the the peak-to-peak error is about nine seconds over the run. I plan to collect data for a few months to see if this is typical.
waitpeq (1<< PPSPin, 1<<PPSPin, 0) GPSCycles += 60 CurrentDelta = GPSCycles - GPSCyclesand in another cog,
waitpeq(1<<Hz60Pin, 1<<Hz60Pin, 0) Hz60Cycles++
It did drift a bit compared to my grandfather's pendulum timed, well, grandfather clock. But I suspect that grandfather clock was more accurate than the mains.
My understanding at the time was that the mains frequency in Blighty would drift throughout the day but they tried to get the count of cycles in a day correct.
Now a days it's so much easier to get accurate timing from GPS, or an oven controlled XTAL clock, or even a rubidium clock off ebay.
Of course you realize the mains frequency in Blighty is consistently slow by 10 Hz, right?
We also consistently have bigger gallons than the US. Which means that beer comes in consistently nice big pints.
What are the units ? You say it is 9 seconds peak-to-peak, but the units go from about +/- 300 ???
Bean
Bean
Sorry, I should have made that more clear. The units *are* cycles. I was just thrilled to get the grid lines at intervals of 60.
Incidentally, I once had a Heathkit digital clock at a place where the mains were so noisey that I had to put a capacitor to filter it to keep from gaining several seconds a day.
Ha, ten years I was involved in rolling out a new system where 200 nodes in a network had to be in sync with the mains. Don't ask why, it's historical.
When it was up and running I was called out to investigate why many nodes were counting time twice as fast as reality. At the week end. A flight from Helsinki to Oslo. God dammit.
Turned out they had designed a new mains filtering/conditioning circuit that fed 50Hz pulses into out digital stuff.
Turned out, after I ripped one of the units apart and looked at the circuit, that it was acting like a high pass filter. Plus they had a lot of noise on the mains. It was counting the harmonics!
I could have done better with a low pass RC circuit. But I'm not the electronics guy in that particular situation.
After they fixed that, redesigned and replaced all those mains conditioners, I was called out again. Another flight. Another day in the rain in the streets of Oslo. Turned out the installers had all the connections of all those units to our digital stuff reversed.
Sometimes, all I want to do is write code....
The WECC (Western Electricity Coordinating Council) has gone to a time error correction at ±30 seconds. This means you should see deviations up to 1 minute over a long period of time.
I have been monitoring this continuously since before the discussions of eliminating time error correction. What use to be ±5 seconds to trigger a correction is now at ±25 seconds to initiate a correction.
That's too bad, but was done to reduce the workload of the Balancing Authorities in synchronizing to other parts of the US-grid. I have a lot of synchronous motor clocks, that while still accurate over the long term, they are sometimes off by ±30 seconds due to the relaxed time error correction.
As a historical note, it was the synchronous motor clock, as invented by Henry Warren, that forced the early electricity companies to stabilize their frequency. He demonstrated in Boston in 1916 that the Edison Electric Illuminating Company had horrible frequency control, and his inventions lead to the ability to use the power lines for timekeeping. The name of the company he founded, Telechron, means "time from a distance".
What 'workload' ?! - surely this is automated, so the numbers become arbitrary, and one would expect these to improve over time, not lurch backwards on a bureaucratic reflex, as seems to be the case here.
What exactly does '±25 seconds to initiate a correction' mean ? - how quickly do they then apply that correction ?
The ±25 seconds means that once the time (as determined by line frequency) has drifted away from the standard amount by 25 seconds, they begin initiating a correction, speeding up or slowing down the line frequency. The goal is to stay within ±30 seconds of the established time. Right now, the WECC is at +18 seconds, and we have been positive for the past week.
You would think Grid frequency balancing (on average) came for free, as part of Grid load balancing.
Ah, bless the Swiss, of course, their Grid info has to include the time
http://www.swissgrid.ch/content/swissgrid/en/home/experts/topics/frequency.html
Currently shows 3.572 s
Also says they correct via +/- 10mHz which means a sustained error of 200ppm could be present for some hours, while they apply the correction.
Interesting. They adjust at ±20 seconds.
Here is the site for ERCOT, the Electric Reliability Council of Texas:
http://www.ercot.com/content/cdr/html/real_time_system_conditions.html
Note they are right at the threshold for starting a correction (as of the time of this post).
My naive assumption is that in a good old national electric grid there are dozens of different power stations of different sorts all connected in parallel to a common grid.
Clearly they all have to be in phase. Surely if some station were to connect whilst out of phase something really bad happens as all the others drive against it!
Is it so that a bunch of AC generators wired in parallel naturally tend to lock together in phase? After all generators are motors and motors are generators so they can all push and pull against each other.
But then how do you get any control over the frequency the whole grid runs at?
And the, we end up connecting national grids together to trade power, who is in control then?
Interconnection is also done with DC ties, which eliminates this problem. Power can be passed between grids without respect to phase, and each grid feeds it into or out of their own synchronous converters.
The Swiss Grid website jmg linked to says that the frequency is dictated by supply and demand. If there's more load per generator, the generators will spin slower because they will be harder to turn. If the frequency is too low, they bring more generators online to compensate.
In the day the solution involved a ridiculous number of vacuum tubes dividing down a 100 KHz crystal oscillator with a lot of fiddling because of divide-by-10 stages preferring to divide by 9 or 11 if not tuned properly. The end result was as complicated as a high-end shortwave radio and existed mainly to provide enough really accurate 60 Hz power to drive a mechanical clock.
