Looking for: electrically-conductive hot melt glue
GordonMcComb
So there's this "Wire Glue" that ThinkGeek and other sell, which is basically an adhesive with graphite. It's a low-end substitute for soldering. Bad news: it takes about 2 hours just to set up, and a day or two to cure. Yuck.
Anyone know of a similar ready-made product for a hot melt glue gun? If also using a graphite-based substance, I'm guessing it might not work as well, due to the heavier ratio of meltable poly to the graphite, but I thought I'd ask. Any metal-bearing hot melt glue would also work, if there is such a thing. Resistance isn't critical (these are low-tech bonds), so it it adds a hundred ohms for a globule, it's probably okay.
I've already ruled out the silver- and nickle-bearing "paints" and epoxies. They're both too expensive (my target is about $5 or less), and the paints don't have much bonding power.
What is wrong with that ?
@Heater, I'm gonna go out on a limb and say safety (high temps) is Gordon's concern here, possibly for young players. Hot melt glue is cooler/safer than solder.
If that is true my mind boggles.
I come from a time when we walked out of the house and were gone all day as soon as we could walk.
At twelve years old we were soldering.
At 13 we were glass blowing and trying to make a mercury switch.
At 14 we were casting molten aluminium. Driving tractors. Being taught how to use industrial sized lathes, mills and shaping machines. Heck, at that age I could have left school and started to work down the coal mines. Luckily I escaped that fate.
How old are these "young players"?
Let them burn their fingers and get some reality under their belt.
I taught 4th graders and up to use soldering irons and I still have 25 irons in storage. Never had a significant burn from them. Hot glue on the other hand resulted in a few minor burns. Neither has much chance of causing significant damage.
Let us know if you find some though Gordon. I'll order some just to play with.
Jonathan
I can well believe that if you want to sell product into the system that is, then you have to "adapt or die".
On the other hand I believe that rearing our children in fluffy, warm, safety blankets is doing them a great dis-service.
Reality bites.
http://www.amazon.com/Permatex-21351-Electrically-Conductive-Defogger/dp/B000HBGKWE
But this looks like what you are looking for (but Cures overnight)
http://www.amazon.com/Sciplus-Electrically-Conductive-Soldering-Wire/dp/B000Z9H7ZW/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1461625803&sr=1-1-catcorr&keywords=Electrically+Conductive+glue
http://www.blackmagic3d.com/Conductive-p/grphn-175.htm
I'm going to contact the graphene filament people to see if they might consider making it in glue sticks for high-temp guns, or they might know someone who has this product already. Some teachers would be willing to do the bundle technique.
Thanks to those who gave constructive suggestions.
My can of CA accelerator has on the label "Keep out of reach of children" !
Back on topic: It might be an interesting experiment to melt hot-melt glue over the stove, blend powdered copper into it, then recast it into a form that would fit a glue gun. A Teflon tube could be used as a mold.
A hold melt gun operating in high temp runs at about 380 degrees F, which is about half that of a soldering gun, but still potentially dangerous. However, it's a tool many schools already use. It would be easier to sell in the concept if the tools were ones already approved by the districts.
How about if I made the conductive hot melt glue sticks? If we are talking tens of thousands this might be worth doing. If it works, other folks might be interested, and more folks would become producers. Maybe.
What cost can yo afford? How much resistance can your circuits tolerate? i.e. In ohms per foot, etc?
To work, you'd need to have adequate liability insurance, D&B rating, and everything else that go into selling to public and private entities. If you're already set up with a business, ideally with a working online storefront (or distributors), it shouldn't be too hard to add this. Otherwise, it can be a real bear.
I haven't yet had a chance to contact Black Magic 3D, but I will soon. and want to try a sample, even if I have to melt it with a shrinkwrap heat gun.
http://www.amazon.com/Scribbler-3D-Pen-Printing-Doodling/dp/B00OT2SI9A
Massimo
Thanks for the idea, though.
