What program created the DAT files?
I assume you mean files with a .dat file extension which is a pretty nondescript extension - could be any format...
It is a big dataset with .dat extension files containing html tags. In each file we have set of documents which I want to extract each as a separate html file. I have no idea what program created the files.
Assuming each document starts with a unique HTML tag and ends with one as well this would be very easy to do. All you have to do is parse the file looking for the start tag, write the data out to a new file until you reach the end tag, rinse and repeat.
I've done this in QuickBASIC 4.5, PDS 7.0, Visual BASIC and once even using the BASIC Stamp 2 with a Memory Stick Datalogger to exract GPS information from a KML file.
I've also done this to update/upgrade one file set to match another (formatting).
You could also do this with a .vbs (visual basic script) utilizing the FileSystemObject TextStream object. The script can be created with Notepad. Just double click the .vbs file to execute the script...
Here is a little script to get you started - it lists cookie exceptions from Chrome settings:
We can't help without some details.
option explicit Const TemporaryFolder = 2 Const ForWriting = 2 Const ForReading = 1 Const TristateFalse = 0 Const TristateTrue = -1 Const TristateUseDefault = -2 Const pattrn = """pattern_pairs"":{" ' Const pattrn2 = """automatic_downloads"":{" Const pattrn2 = """automatic_downloads"":{},""cookies"":{" dim WSHShell, fso, ts, UserProfile, PrefsFldr, ChromePrefs dim shell set shell = CreateObject("Shell.Application") Set WSHShell = WScript.CreateObject("WScript.Shell") Set fso = CreateObject("Scripting.FileSystemObject") UserProfile = WSHShell.ExpandEnvironmentStrings("%UserProfile%") ' PrefsFldr = fso.BuildPath(UserProfile, "\Local Settings\Application Data\Google\Chrome\User Data\Default\Preferences") PrefsFldr = fso.BuildPath(UserProfile, "AppData\Local\Google\Chrome\User Data\Default\Preferences") ' "C:\Users\Ron Czapala\AppData\Local\Google\Chrome\User Data\Default\Preferences" If fso.FileExists(PrefsFldr) Then GetPrefs else msgbox PrefsFldr,vbcritical, "Not found" end if Public Sub GetPrefs() dim idx, idy, msg, xcepts, i, mydocs, xfile, xts Set ts = fso.OpenTextFile(PrefsFldr, ForReading, False, TristateFalse) ChromePrefs = ts.ReadAll ' msgbox len(ChromePrefs) ts.Close mydocs = WshShell.SpecialFolders("MyDocuments") xfile = fso.BuildPath(mydocs, "Exceptions.htm") set xts = fso.CreateTextFile(xfile, True, False) HTML1 xts xts.writeline PrefsFldr & "<BR><HR>" idx = InStr(1,ChromePrefs, pattrn2, vbTextCompare) if idx > 0 then ChromePrefs = Mid(ChromePrefs, idx + len(pattrn2)+1) idx = InStr(1, ChromePrefs, "}}", vbTextCompare) If idx > 0 Then ChromePrefs = Mid(ChromePrefs, 1, idx + 1) End If ' msgbox ChromePrefs idy = InStr(idx, ChromePrefs, "[*.]") xcepts = Split(ChromePrefs, "},""") xts.writeline Ubound(xcepts) & " entries<BR>" ' for i = 0 to 5 ' msgbox xcepts(i) ' next ' xts.writeline UBound(xcepts) & "<BR>" For i = 0 To UBound(xcepts) If InStr(xcepts(i), "[*.]") > 0 then ' If InStr(xcepts(i), """cookies"":") > 0 Then If InStr(xcepts(i), """setting"":") > 0 Then xts.writeline Process_Entry(xcepts(i)) & "<BR>" End If End If Next Else Msgbox pattrn & " not found",vbCritical,"Error" End If HTML2 xts xts.close shell.Open xfile End Sub Private Sub HTML1(xts) xts.write "<HTML><head><title>Chrome Cookie Exceptions</title>" & vbcrlf xts.write "</head>" & vbcrlf xts.write "<body>" & vbcrlf xts.write "<font color='navy' style=' FONT-FAMILY: Verdana, Tahoma; FONT-SIZE: 12px'>" End sub Private Sub HTML2(xts) xts.write "</font>" xts.write "</Body>" & vbcrlf & "</HTML>" End sub Private Function Process_Entry(entry) Dim idx, idy Dim retval, cval retval = Replace(entry, "[*.]", "") ' msgbox retval ' idy = InStr(retval, "cookies" & chr(34) & ":") + 9 idy = InStr(retval, "setting" & chr(34) & ":") + 9 cval = mid(retval, idy, 1) if cval = "1" then cval = "Allow" end if idx = InStr(retval, ",") on error resume next retval = Left(retval, idx - 1) if err.number <> 0 then msgbox entry,,idx Process_Entry = entry else Process_Entry = cval & " " & retval end if End Function
