Convert DAT files to HTML files — Parallax Forums
Any suggestions how I can convert DAT files to HTML files other than online available tools as they are not working for my files? Thanks
  • What program created the DAT files?
    I assume you mean files with a .dat file extension which is a pretty nondescript extension - could be any format...
    What DAT files? How would you like them to look in HTML? What on line tools don't work?
    We can't help without some details.
  • It is a big dataset with .dat extension files containing html tags. In each file we have set of documents which I want to extract each as a separate html file. I have no idea what program created the files.
    edited 2016-04-22 15:01
    Assuming each document starts with a unique HTML tag and ends with one as well this would be very easy to do. All you have to do is parse the file looking for the start tag, write the data out to a new file until you reach the end tag, rinse and repeat.
    I've done this in QuickBASIC 4.5, PDS 7.0, Visual BASIC and once even using the BASIC Stamp 2 with a Memory Stick Datalogger to exract GPS information from a KML file.
    I've also done this to update/upgrade one file set to match another (formatting).
  • Assuming each document starts with a unique HTML tag and ends with one as well this would be very easy to do. All you have to do is parse the file looking for the start tag, write the data out to a new file until you reach the end tag, rinse and repeat.
    You could also do this with a .vbs (visual basic script) utilizing the FileSystemObject TextStream object. The script can be created with Notepad. Just double click the .vbs file to execute the script...
    Here is a little script to get you started - it lists cookie exceptions from Chrome settings:
    option explicit
      Const TemporaryFolder = 2
      Const ForWriting = 2
      Const ForReading = 1
      Const TristateFalse = 0
      Const TristateTrue = -1
      Const TristateUseDefault = -2
      Const pattrn = """pattern_pairs"":{"
    '  Const pattrn2 = """automatic_downloads"":{"
      Const pattrn2 = """automatic_downloads"":{},""cookies"":{"
      dim WSHShell, fso, ts, UserProfile, PrefsFldr, ChromePrefs
      dim shell
      set shell = CreateObject("Shell.Application")
      Set WSHShell = WScript.CreateObject("WScript.Shell")
      Set fso = CreateObject("Scripting.FileSystemObject")
      UserProfile = WSHShell.ExpandEnvironmentStrings("%UserProfile%")
    '  PrefsFldr = fso.BuildPath(UserProfile, "\Local Settings\Application Data\Google\Chrome\User Data\Default\Preferences")
      PrefsFldr = fso.BuildPath(UserProfile, "AppData\Local\Google\Chrome\User Data\Default\Preferences")
    ' "C:\Users\Ron Czapala\AppData\Local\Google\Chrome\User Data\Default\Preferences"
      If fso.FileExists(PrefsFldr) Then
        GetPrefs
      else
        msgbox PrefsFldr,vbcritical, "Not found"
       end if
    Public Sub GetPrefs()
      dim idx, idy, msg, xcepts, i, mydocs, xfile, xts
      Set ts = fso.OpenTextFile(PrefsFldr, ForReading, False, TristateFalse)
      ChromePrefs = ts.ReadAll
    '  msgbox len(ChromePrefs)
      ts.Close
      mydocs = WshShell.SpecialFolders("MyDocuments")
      xfile = fso.BuildPath(mydocs, "Exceptions.htm")
      set xts = fso.CreateTextFile(xfile, True, False)
      HTML1 xts
      xts.writeline PrefsFldr & "<BR><HR>"
      idx = InStr(1,ChromePrefs,  pattrn2, vbTextCompare)
      if idx > 0 then
        ChromePrefs = Mid(ChromePrefs, idx + len(pattrn2)+1)
        idx = InStr(1, ChromePrefs, "}}", vbTextCompare)
        If idx > 0 Then
          ChromePrefs = Mid(ChromePrefs, 1, idx + 1)
        End If
    '    msgbox ChromePrefs
        idy = InStr(idx, ChromePrefs, "[*.]")
        xcepts = Split(ChromePrefs, "},""")
        xts.writeline Ubound(xcepts) & " entries<BR>"
    '    for i = 0 to 5
    '     msgbox xcepts(i)
    '   next
    '     xts.writeline  UBound(xcepts) & "<BR>"
        For i = 0 To UBound(xcepts)
          If InStr(xcepts(i), "[*.]") > 0 then
    '         If InStr(xcepts(i), """cookies"":") > 0 Then
             If InStr(xcepts(i), """setting"":") > 0 Then
              xts.writeline Process_Entry(xcepts(i)) & "<BR>"
            End If
          End If
        Next
      Else
        Msgbox pattrn & " not found",vbCritical,"Error"
      End If
      HTML2 xts
      xts.close
      shell.Open xfile
    End Sub
    Private Sub HTML1(xts)
      xts.write "<HTML><head><title>Chrome Cookie Exceptions</title>" & vbcrlf
      xts.write "</head>" & vbcrlf
      xts.write "<body>" & vbcrlf
      xts.write "<font color='navy' style=' FONT-FAMILY: Verdana, Tahoma; FONT-SIZE: 12px'>"
    End sub
    Private Sub HTML2(xts)
       xts.write "</font>"
       xts.write "</Body>" & vbcrlf & "</HTML>"
    End sub
    Private Function Process_Entry(entry)
      Dim idx, idy
      Dim retval, cval
      retval = Replace(entry, "[*.]", "")
    '  msgbox retval
    '  idy = InStr(retval, "cookies" & chr(34) & ":") + 9
      idy = InStr(retval, "setting" & chr(34) & ":") + 9
      cval = mid(retval, idy, 1)
      if cval = "1" then
        cval = "Allow"
      end if
      idx = InStr(retval, ",")
      on error resume next
      retval = Left(retval, idx - 1)
      if err.number <> 0 then
        msgbox entry,,idx
        Process_Entry = entry
      else
        Process_Entry = cval & " " & retval
      end if
    End Function
