24" automated sliding platform
Hello,
I'm looking for a sliding platform that I can control with a computer or microcontroller. Basically something like this, but triggerable from another control system: http://konovaphoto.com/motion-control/msbbundle.html
I only needs to have a travel a bout 24" and does not have to be fast. 60 seconds from one end to the other is fine. It also doesn't need to stop or be tracked anywhere in the middle. The commands it would receive would just be "move to point A", "move to point B". Any off the shelf product ideas?
Marcus
Marcus
Many linear actuators can be manually wired to do what you're asking without a controller. Just some wires and a couple of buttons.
http://www.robotshop.com/en/firgelli-technologies-l16-actuator-140mm-351-6v-rc-control.html
If it were me, I'd just make a flattish rolling platform, using small wheels locked onto a pair of rotating axles to ensure it rolls straight on a flat surface. Then motorize one axle with either a stepper motor or a gearmotor & encoder. Easy peezy.
Along those lines, I need to make a turntable for video shoots. Mount a CR servo on the bottom of a disk, shaft pointing down into a support base. IR remote control for speed, direction, and stop functions. Easy peezy.
