Multirotor control theory
WolvesOfTheNight
in Robotics
As noted elsewhere I am working on a quadcopter control project. I am currently looking for good documentation on multirotor control theory. I am doing the usual web searching and have found some good information such as this PDF. However, web searches do not always come up with the best sources.
Are there any sources you would recommend? Online sources are nice, but I am happy to track down a book if necessary. I also have access to some journals through the university library (and I will be searching those as time allows).
http://learn.parallax.com/elev-8
Here are some articles freely available off the internet. You may have already looked at them. I find the first one quite useful as a starting point;
1) http://owenson.me/build-your-own-quadcopter-autopilot/
2) Full Quaternion Based Attitude Control for a Quadrotor
Emil Fresk and George Nikolakopoulos
3) Foundation of Computer Science FCS, New York, USA Volume 9 – No.8, October 2015 – www.ijais.org
Euler and Quaternion Parameterization in VTOL UAV Dynamics with Test Model Efficiency
Redouane Dargham
Doctoral Student in Computer Engineering National Higher School of Electricity and Mechanics
(EAS, LISER, ENSEM)
Adil Sayouti
PhD Professor,
Mechanics
(ENSEM, EAS, LISER)
Hicham Medromi
PhD ,Professor and Director National Higher School of Electricity and
Mechanics
(ENSEM, EAS, LISER)
The paper you linked is inaccurate in at least one spot: "If our gyro is precise enough, we can integrate the values obtained from the gyro to get the angles θ and φ." This glosses over one of the larger complexities of the IMU - rotations are not commutative, so simple integration doesn't work, and accumulating errors have to be dealt with and corrected.
Some resources I found useful:
http://ai.stanford.edu/~gabeh/papers/Quadrotor_Dynamics_GNC07.pdf
http://www.x-io.co.uk/open-source-imu-and-ahrs-algorithms/
http://www.starlino.com/dcm_tutorial.html
http://www.nt.ntnu.no/users/skoge/prost/proceedings/ecc-2013/data/papers/0927.pdf
