If you have a laser rangefinger that is not either of those, please post!
Also, if you have questions about those two pages, please ask. When I did those they made sense at the time and appeared to work, but I don't know if anybody else tried them yet. There may be errors.
This is really interesting. What is INA226 used for in an application? For example, can we measure current and voltage to a DC motor, and determine how much load the motor is seeing as any given measurement?
Changing shunt-resistor get different measure-range and resolution.
This module use 0.025ohm; Resolution=0.1mA Range=-3.2768A to +3.2767A
If shunt-resistor is 0.002ohm; Resolution=1mA Range=-32.768A to +32.767A
This can connect both Hi-side and Lo-side for motor,etc.
Application are power monitor,motor current monitor, etc.
shunt-voltage,Bus voltage,power can issue limit-alert to alert-pin.
This module cost 1000yen(about $8).
I had written code about Charlieplexing in Novenber 2014.
Date is unknown. I seems this forum delete date.
I found out there is bug in Charlieplexing_8x8Matrix_0.3_1.f
I re-write code and summary.
But summary is bigger than 2M.
Cannot upload.
I upload only "Charlieplexing_8x8Matrix_0.3_2".
Re-wrote word are 'matrix_Charlie_fth' and '_matrix_Charlie_asm'.
Caskaz,
What are you trying to do? Are you using a touch panel and trying to determine where it is pressed?
If so, you can use the props sigma delta to do this but may not be as precise as you require. IIRC I posted pasm code in a thread a few years ago. Not sure if I put it in obex.
I wrote code for TouchScreenController(ADS7843) by using SPI-communication.
When pen touched on touchscreen, measurment start.
Data(x,y) are average-value[8samples].
fl
TouchScreen Controller(ADS7843)
PropForth5.52015/12/3013:19:29---------------- 3V3-- |Vref Vcc| -- 3V3 -----------
P5 -----> |cs X+| --------- | |
P6 -----> |clk X-| --------- |TouchScreen|
P7 -----> |din ADS7843 Y+| --------- | |
P8 <----- |dout Y-| --------- | |3V3 | | -----------
10k | |
P9 <----- |PENIRQ |
| GND |
GND
TouchPosition(X,Y) is averaged by sampled 8 times.
\ Constants
\ -------------------------------------------------------5 wconstant cs
6 wconstant clk
7 wconstant din
8 wconstant dout
1 dout lshift constant doutm
9 wconstant penirq
1 penirq lshift constant penirqm
\ A/D selection
9 wconstant Ydata
hD wconstant Xdata
hA wconstant Aux1
hE wconstant Aux2
\ Resolution
0 wconstant 12bit
1 wconstant 8bit
\ Single/Differential
0 wconstant diff
1 wconstant single
\ PowerDown selection
0 wconstant enablePD
1 wconstant disablePD
8 wconstant average
\ Variables
wvariable cont_X
wvariable cont_Y
wvariable contAux1
wvariable contAux2
\ Main
\ Set clk to Hi
: clk_h clk pinhi ;
\ Set clk to Lo
: clk_l clk pinlo ;
\ Set din to Hi
: din_h din pinhi ;
\ Set din to Lo
: din_l din pinlo ;
\ Set control byte(X and Y) for TouchScreen
\ ( n1 n2 n3 -- ) n1:mode n2:single/differential n3:PowerDown
: setTSC
swap 2 lshift or
swap 3 lshift or
dup
Ydata 4 lshift or cont_Y W!
Xdata 4 lshift or cont_X W!
\ Set control byte(Aux1 and Aux2) for Aux
: setAux
swap 2 lshift or
swap 3 lshift or
dup
Aux1 4 lshift or contAux1 W!
Aux2 4 lshift or contAux2 W!
\ SPI communication
\ ( n1 -- n2 ) n1;control byte n2:data
: 24bitSPI
cs pinlo
0 swap \ ( 0 n1 )
d16 lshift h800000 \ ( 0 n1 h800000 )
d24 0do
\ transmitt
2dup \ ( 0 n1 h800000 n1 h800000 )
andif din_h else din_l then
clk_h \ Send 1bit to din
\ receive
rot \ ( n1 h800000 0 )
ina COG@ doutm andif1orthen1 lshift rot2 \ Receive 1bit from dout
clk_l
1 rshift
loop
2drop
1 rshift
cs pinhi
\ Get A/D 1data
: rdA/D
dup 24bitSPI \ ( n1 [received data] )
swap 8and \ ( [received data] 1/0 )
if
\ 8bit mode
7 rshift hFF andelse
\ 12bit mode
3 rshift hFFF andthen \ ( n2 )
\ Get Touch position
: rdTouch
0 \ initial sum for Y
average 0do
cont_Y W@ rdA/D
loop
average u/
0 \ initial sum for X
average 0do
cont_X W@ rdA/D
loop
average u/
: demo
\ Set data for TouchScreenController
12bit diff enablePD setTSC
\ Set output port
cs pinhi cs pinout clk pinout din pinout
begin
begin ina COG@ penirqm and0= until \ Wait until pen-touch is detected
rdTouch ." X:" . ." Y:". cr
fkey? swap drop
until
8bit diff enablePD setTSC
begin
fkey? swap drop
until
\ Time to get X-position
: test2 cnt COG@ cont_X W@ rdA/D cnt COG@ nip swap - dup . ." ticks " d80 u/ . ." usec" ;
I wrote TouchScreen Controller' code by using 2cog.
Cog6 send control-byte and clock.
Cog0 receive A/D conversion data from ADS7843.
8data need 136clocks(12bit mode), 104clocks(8bit mode).
Above SPI code, it need 24clock(12bit mode/8bit mode).
It need 196clock at 8data.
fl
PropForth5.52016/01/0112:28:21---------------- 3V3-- |Vref Vcc| -- 3V3 -----------
10k | |
P9 <----- |PENIRQ |
P10 <---- |busy |
| GND |
GND
\ Constants
1 cs lshift constant csm
6 wconstant clk
1 clk lshift constant clkm
7 wconstant din
8 wconstant dout
9 wconstant penirq
d10 wconstant busy
1 busy lshift constant busym
\ A/D selection
9 wconstant Ydata
hD wconstant Xdata
hA wconstant Aux1
hE wconstant Aux2
\ Mode
0 wconstant 12bit
1 wconstant 8bit
0 wconstant diff
1 wconstant single
3 wconstant disablePD
8 wconstant average
\ Variables
wvariable cont_X
wvariable cont_Y
wvariable posX
wvariable posY
wvariable aveVal
\ Main
\ Output clk-pulse
: clk_pulse clk pinhi clk pinlo ;
\ Set din to Hi
: din_h din pinhi ;
\ Set din to Lo
: din_l din pinlo ;
\ Set control byte(X and Y) for ADS7843
: setTSC
swap 2 lshift or
swap 3 lshift or
dup
\ Wait until busy fall down
: waitBusy
begin ina COG@ busym anduntil
begin ina COG@ busym and0= until
: waitBusy
busym busym waitpeq \ Wait until busy goes to Hi
busym busym waitpne \ Wait until busy goes to Lo
\ Read A/D conversion data
\ ( n1 -- n2 ) n1:8 or 12 n2:A/D conversion value
: rdA/D
0 \ Initial value
swap 0do1 lshift
clkm clkm waitpeq \ Wait until clk go to Hi
clkm clkm waitpne \ Wait until clk go to Lo
loop
\ Get average value
\ ( -- n1 ) n1:average value
: rdTS
begin
begin ina COG@ csm and0= until \ Wait until cs goes to Lo
0 \ Initial average value
average 0do
waitBusy \ Wait until busy fall down
cont_X W@ 8and \ Check mode
if8else d12 then
rdA/D \ Get A/D value
loop
8 u/ aveVal W!
begin ina COG@ csm anduntil \ Wait until cs goes to Hi
0until
\ Send controlByte(8bit) and only clock-pulse
\ ( n1 -- ) n1:control byte
: sendData
h80
80do2dup andif din_h else din_l then
clk_pulse
1 rshift
loop
2drop
\ Send clock
if4else8then0do
clk_pulse
11 * drop \ Dummy delay
loop
\ Send extra clock
: extraCLK
cont_X W@ 8and \ Check mode(8bit or12bit)
if d12 else d16 then0do
clk_pulse
loop
\ Display (X.Y)
\ Cog6 send control-byteand extra clockand Cog0 read A/D conversion data
: demo
\ Set data for TouchScrenn
c" rdTS"0 cogx
begin
penirqm penirqm waitpne \ Check touch
\ --- X ---
cs pinlo \ Activate cs
\ X
average 0do
\ Send control-byte
cont_X W@ sendData
loop
extraCLK
aveVal W@ posX W!
cs pinhi \ Deactivate cs
\ --- Y ---
\ Y
average 0do
\ Send control-byte
cont_Y W@ sendData
loop
extraCLK
aveVal W@ posY W!
." X:" posX W@ . ." Y:" posY W@ . cr
fkey? swap drop
until0 cogreset
\ Display timefor X-position(sample:8 data) and (X.Y)
: demo1
c" rdTS"0 cogx
begin
\ --- X ---
cnt COG@
\ X
average 0do
\ Send control-byte
cont_X W@ sendData
loop
extraCLK
aveVal W@ posX W!
cnt COG@ swap - .
\ --- Y ---
\ Y
average 0do
\ Send control-byte
cont_Y W@ sendData
loop
extraCLK
aveVal W@ posY W!
fkey? swap drop
until0 cogreset
Today is her Birthday.(January 2)
She is 12 years old.
Hi,
I have a GPS module with serial NMA0183 output ( 4800 8n1 ) and a propeller board with propforth installed
My idea is to read the NMEA data from the propeller serial interface and display it on a LCD, but the serial port is normally used by the terminal session of propforth. Is it possible to detect a NMEA sentence like:
$GPGGA,191410,4735.5634,N,00739.3538,E,1,04,4.4,351.5,M,48.0,M,,*45
in the input stream and extract and store the data in table for example ?
Any ideas ?
Hi,
Any ideas ?
Sven
Alright then, closest I could help you here is a little bit that I did in Tachyon Forth in this post but have a look through the thread. Basically it involves telling Tachyon that the comma is a delimiter and to essentially post process the string.
Did you ever figure out the random issue with your PID demo?
One thing I ran across (yet again) that causes random reset:
If my diagnostic code (running on cog 6) prints too fast, it will choke the serial link.
That is, if I am printing a page worth of characters to the terminal screen, but I don't leave enough time between pages, eventually something will crash. I had a delay of 10 ms (10 delms) between screens and it would randomly crash after several hours. I changed the diagnostic to display once every second, and it now runs for days and hasn't crashed again.
This is stuff I have for both:
this page https://code.google.com/p/propforth/wiki/LIDARLite
for I2C (faster communications but not serial)
and this page https://code.google.com/p/propforth/wiki/SF02LaserRangeFinder
for serial (easier if you know only serial and not I2C)
Used only sound part of code"SimpleGame2_0.1" below;
http://forums.parallax.com/discussion/146693/propforth-v5-5-is-available-for-download/p18
[video]
Shunt-resistor is 0.025ohm.
Using i2c_utility_0.4_1.f.
i2c_utility_0.4_1.f. modified only comments from i2c_utility_0.4.f.
INA226's reading from I2C use 'i2c_rd_multi'.
(PDF procedure is different.)
I found out 'i2c_wr_multi is also available.
I will update code later.
Prop0 Cog6 ok i2c_detect 0 1 2 3 4 5 6 7 8 9 A B C D E F 00: 00 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- <-- INA226 reply 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- 39 -- -- -- -- -- -- <-- APDS-9960 40: 40 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- <-- INA226 50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- <-- eeprom 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- i2c_device:3 [0 - 7] and [h78 - h7F] are reserve-address Prop0 Cog6 ok ID Manufacture ID:h5449 Die ID:h2260 Prop0 Cog6 ok init_INA226 Prop0 Cog6 ok dispReg Register Value Configuration(h00): h4727 Shunt Voltage(h01): d47 Bus Voltage(h02): d2625 Power(h03): d7 Current(h04): d47 Calibration(h05): d2048 Mask/Enable(h06): h8 Alert Limit(h07): d0 Prop0 Cog6 ok demo Bus_V:3272 mV Current:4 .6 mA Power:17 mW Bus_V:3272 mV Current:4 .7 mA Power:17 mW Bus_V:3272 mV Current:4 .6 mA Power:17 mW Bus_V:3272 mV Current:4 .6 mA Power:17 mW Bus_V:3272 mV Current:4 .6 mA Power:17 mW Bus_V:3272 mV Current:4 .6 mA Power:17 mW Bus_V:3272 mV Current:4 .6 mA Power:17 mW Bus_V:3272 mV Current:4 .6 mA Power:17 mW Bus_V:3272 mV Current:4 .6 mA Power:17 mW Bus_V:3272 mV Current:4 .6 mA Power:17 mW Bus_V:3272 mV Current:4 .6 mA Power:17 mW Bus_V:3272 mV Current:4 .6 mA Power:17 mW Bus_V:3272 mV Current:4 .6 mA Power:17 mW Prop0 Cog6 ok
demo Bus_V:3272 mV Current:-4 .6 mA Power:17 mW Bus_V:3272 mV Current:-4 .7 mA Power:17 mW Bus_V:3272 mV Current:-4 .6 mA Power:17 mW Bus_V:3272 mV Current:-4 .6 mA Power:17 mW Bus_V:3272 mV Current:-4 .6 mA Power:17 mW Prop0 Cog6 ok
Cannot upload.
Using TouchScreen under noise;
1) Using capacitance
2) Averasing value(x,y)
3) Measuring TouchPressure, Use it as threshold value
This time, measured TouchPress.
This use float.f
Prop0 Cog6 ok getZ * * * <--- Not touch * * * * <--- Touching * * * * * * * * * * * * * * * * * Prop0 Cog6 ok
4096 is resolution of ADC(MCP3204).
I'm going to practice Github.
I uploaded "Charlieplexing".
https://github.com/caskaz/PropForth5.5
I erase someday because of practice.
fl { TouchScreen Controller(ADS7843) PropForth5.5 2015/12/27 13:21:41 -------------- 3V3-- |Vref Vcc| -- 3V3 ----------- P5 -----> |cs X+| --------- | | P6 -----> |clk X-| --------- |TouchScreen| P7 -----> |din ADS7843 Y+| --------- | | P8 <----- |dout Y-| --------- | | | GND | ----------- ---------------- | GND } \ ------------------------------------------------------- \ Constants \ ------------------------------------------------------- 5 wconstant cs 6 wconstant clk 7 wconstant din 8 wconstant dout 1 dout lshift constant doutm \ A/D selection 1 wconstant Ydata 5 wconstant Xdata 2 wconstant Aux1 6 wconstant Aux2 \ Resolution 0 wconstant 12bitData 1 wconstant 8bitData \ Single/Differential 0 wconstant diff 1 wconstant single \ PowerDown selection 0 wconstant enablePD 1 wconstant disablePD \ ------------------------------------------------------- \ Variables \ ------------------------------------------------------- \ ------------------------------------------------------- \ Main \ ------------------------------------------------------- \ Output clk-pulse \ ( -- ) : clk_pulse clk pinhi clk pinlo ; \ Set din to Hi \ ( -- ) : din_h din pinhi ; \ Set din to Lo \ ( -- ) : din_l din pinlo ; \ Convert analog to digital \ ( n1 n2 n3 n4 -- n5 ) n1:PD n2:single/diff(select single when Aux1/Aux2) n3:mode n4:address n5:conversion data : ADS7843 \ Set output port cs pinhi cs pinout clk pinout din pinout cs pinlo 1 \ Start bit 3 lshift or \ Add address over >r \ Push mode 1 lshift or \ Add mode 1 lshift or \ Add single/diff 2 lshift or \ Add PD \ Send control data h80 8 0 do 2dup and if din_h else din_l then clk_pulse 1 rshift loop 2drop clk_pulse \ Read data 0 r> \ Pop mode dup >r \ Push mode if 8 else d12 then 0 do 1 lshift clk pinhi ina COG@ doutm and if 1 or then clk pinlo loop r> if clk_pulse clk_pulse clk_pulse else 7 0 do clk_pulse loop then cs pinhi ; \ Display 12bit(x,y) on TouchScreen \ ( -- ) : demo begin enablePD diff 12bitData Ydata ADS7843 d2047 - . enablePD diff 12bitData Xdata ADS7843 d2047 - . cr d100 delms fkey? swap drop until ; \ Display 8bit(x,y) on TouchScreen \ ( -- ) : demo1 begin enablePD diff 8bitData Ydata ADS7843 d127 - . enablePD diff 8bitData Xdata ADS7843 d127 - . cr d100 delms fkey? swap drop until ;
fl { TouchScreen Controller(ADS7843) PropForth5.5 2015/12/30 13:19:29 ---------------- 3V3-- |Vref Vcc| -- 3V3 ----------- P5 -----> |cs X+| --------- | | P6 -----> |clk X-| --------- |TouchScreen| P7 -----> |din ADS7843 Y+| --------- | | P8 <----- |dout Y-| --------- | | 3V3 | | ----------- | | | 10k | | | | | P9 <----- |PENIRQ | | GND | ---------------- | GND TouchPosition(X,Y) is averaged by sampled 8 times. } \ ------------------------------------------------------- \ Constants \ ------------------------------------------------------- 5 wconstant cs 6 wconstant clk 7 wconstant din 8 wconstant dout 1 dout lshift constant doutm 9 wconstant penirq 1 penirq lshift constant penirqm \ A/D selection 9 wconstant Ydata hD wconstant Xdata hA wconstant Aux1 hE wconstant Aux2 \ Resolution 0 wconstant 12bit 1 wconstant 8bit \ Single/Differential 0 wconstant diff 1 wconstant single \ PowerDown selection 0 wconstant enablePD 1 wconstant disablePD 8 wconstant average \ ------------------------------------------------------- \ Variables \ ------------------------------------------------------- wvariable cont_X wvariable cont_Y wvariable contAux1 wvariable contAux2 \ ------------------------------------------------------- \ Main \ ------------------------------------------------------- \ Set clk to Hi \ ( -- ) : clk_h clk pinhi ; \ Set clk to Lo \ ( -- ) : clk_l clk pinlo ; \ Set din to Hi \ ( -- ) : din_h din pinhi ; \ Set din to Lo \ ( -- ) : din_l din pinlo ; \ Set control byte(X and Y) for TouchScreen \ ( n1 n2 n3 -- ) n1:mode n2:single/differential n3:PowerDown : setTSC swap 2 lshift or swap 3 lshift or dup Ydata 4 lshift or cont_Y W! Xdata 4 lshift or cont_X W! ; \ Set control byte(Aux1 and Aux2) for Aux \ ( n1 n2 n3 -- ) n1:mode n2:single/differential n3:PowerDown : setAux swap 2 lshift or swap 3 lshift or dup Aux1 4 lshift or contAux1 W! Aux2 4 lshift or contAux2 W! ; \ SPI communication \ ( n1 -- n2 ) n1;control byte n2:data : 24bitSPI cs pinlo 0 swap \ ( 0 n1 ) d16 lshift h800000 \ ( 0 n1 h800000 ) d24 0 do \ transmitt 2dup \ ( 0 n1 h800000 n1 h800000 ) and if din_h else din_l then clk_h \ Send 1bit to din \ receive rot \ ( n1 h800000 0 ) ina COG@ doutm and if 1 or then 1 lshift rot2 \ Receive 1bit from dout clk_l 1 rshift loop 2drop 1 rshift cs pinhi ; \ Get A/D 1data \ ( n1 -- n2 ) n1;control byte n2:data : rdA/D dup 24bitSPI \ ( n1 [received data] ) swap 8 and \ ( [received data] 1/0 ) if \ 8bit mode 7 rshift hFF and else \ 12bit mode 3 rshift hFFF and then \ ( n2 ) ; \ Get Touch position \ ( -- ) : rdTouch 0 \ initial sum for Y average 0 do cont_Y W@ rdA/D + loop average u/ 0 \ initial sum for X average 0 do cont_X W@ rdA/D + loop average u/ ; : demo \ Set data for TouchScreenController 12bit diff enablePD setTSC \ Set output port cs pinhi cs pinout clk pinout din pinout begin begin ina COG@ penirqm and 0= until \ Wait until pen-touch is detected rdTouch ." X:" . ." Y:". cr fkey? swap drop until \ Set data for TouchScreenController 8bit diff enablePD setTSC begin begin ina COG@ penirqm and 0= until \ Wait until pen-touch is detected rdTouch ." X:" . ." Y:". cr fkey? swap drop until ; \ Time to get X-position \ ( -- ) : test2 cnt COG@ cont_X W@ rdA/D cnt COG@ nip swap - dup . ." ticks " d80 u/ . ." usec" ;
fl { TouchScreen Controller(ADS7843) PropForth5.5 2016/01/01 12:28:21 ---------------- 3V3-- |Vref Vcc| -- 3V3 ----------- P5 -----> |cs X+| --------- | | P6 -----> |clk X-| --------- |TouchScreen| P7 -----> |din ADS7843 Y+| --------- | | P8 <----- |dout Y-| --------- | | 3V3 | | ----------- | | | 10k | | | | | P9 <----- |PENIRQ | P10 <---- |busy | | GND | ---------------- | GND } \ ------------------------------------------------------- \ Constants \ ------------------------------------------------------- 5 wconstant cs 1 cs lshift constant csm 6 wconstant clk 1 clk lshift constant clkm 7 wconstant din 8 wconstant dout 1 dout lshift constant doutm 9 wconstant penirq 1 penirq lshift constant penirqm d10 wconstant busy 1 busy lshift constant busym \ A/D selection 9 wconstant Ydata hD wconstant Xdata hA wconstant Aux1 hE wconstant Aux2 \ Mode 0 wconstant 12bit 1 wconstant 8bit \ Single/Differential 0 wconstant diff 1 wconstant single \ PowerDown selection 0 wconstant enablePD 3 wconstant disablePD 8 wconstant average \ ------------------------------------------------------- \ Variables \ ------------------------------------------------------- wvariable cont_X wvariable cont_Y wvariable posX wvariable posY wvariable aveVal \ ------------------------------------------------------- \ Main \ ------------------------------------------------------- \ Output clk-pulse \ ( -- ) : clk_pulse clk pinhi clk pinlo ; \ Set din to Hi \ ( -- ) : din_h din pinhi ; \ Set din to Lo \ ( -- ) : din_l din pinlo ; \ Set control byte(X and Y) for ADS7843 \ ( n1 n2 n3 -- ) n1:mode n2:single/differential n3:PowerDown : setTSC swap 2 lshift or swap 3 lshift or dup Ydata 4 lshift or cont_Y W! Xdata 4 lshift or cont_X W! ; \ Wait until busy fall down \ ( -- ) : waitBusy begin ina COG@ busym and until begin ina COG@ busym and 0= until ; : waitBusy busym busym waitpeq \ Wait until busy goes to Hi busym busym waitpne \ Wait until busy goes to Lo ; \ Read A/D conversion data \ ( n1 -- n2 ) n1:8 or 12 n2:A/D conversion value : rdA/D 0 \ Initial value swap 0 do 1 lshift clkm clkm waitpeq \ Wait until clk go to Hi ina COG@ doutm and if 1 or then clkm clkm waitpne \ Wait until clk go to Lo loop ; \ Get average value \ ( -- n1 ) n1:average value : rdTS begin begin ina COG@ csm and 0= until \ Wait until cs goes to Lo 0 \ Initial average value average 0 do waitBusy \ Wait until busy fall down cont_X W@ 8 and \ Check mode if 8 else d12 then rdA/D \ Get A/D value + loop 8 u/ aveVal W! begin ina COG@ csm and until \ Wait until cs goes to Hi 0 until ; \ Send controlByte(8bit) and only clock-pulse \ ( n1 -- ) n1:control byte : sendData h80 8 0 do 2dup and if din_h else din_l then clk_pulse 1 rshift loop 2drop \ Send clock cont_X W@ 8 and \ Check mode if 4 else 8 then 0 do clk_pulse 1 1 * drop \ Dummy delay loop ; \ Send extra clock \ ( -- ) : extraCLK cont_X W@ 8 and \ Check mode(8bit or 12bit) if d12 else d16 then 0 do clk_pulse 1 1 * drop \ Dummy delay loop ; \ Display (X.Y) \ Cog6 send control-byte and extra clock and Cog0 read A/D conversion data \ ( -- ) : demo \ Set data for TouchScrenn 12bit diff enablePD setTSC cs pinhi cs pinout clk pinout din pinout c" rdTS" 0 cogx begin penirqm penirqm waitpne \ Check touch \ --- X --- cs pinlo \ Activate cs \ X average 0 do \ Send control-byte cont_X W@ sendData loop extraCLK aveVal W@ posX W! cs pinhi \ Deactivate cs \ --- Y --- cs pinlo \ Activate cs \ Y average 0 do \ Send control-byte cont_Y W@ sendData loop extraCLK aveVal W@ posY W! cs pinhi \ Deactivate cs ." X:" posX W@ . ." Y:" posY W@ . cr fkey? swap drop until 0 cogreset ; \ Display time for X-position(sample:8 data) and (X.Y) \ ( -- ) : demo1 \ Set data for TouchScrenn 12bit diff enablePD setTSC cs pinhi cs pinout clk pinout din pinout c" rdTS" 0 cogx begin penirqm penirqm waitpne \ Check touch \ --- X --- cnt COG@ cs pinlo \ Activate cs \ X average 0 do \ Send control-byte cont_X W@ sendData loop extraCLK aveVal W@ posX W! cs pinhi \ Deactivate cs cnt COG@ swap - . \ --- Y --- cs pinlo \ Activate cs \ Y average 0 do \ Send control-byte cont_Y W@ sendData loop extraCLK aveVal W@ posY W! cs pinhi \ Deactivate cs ." X:" posX W@ . ." Y:" posY W@ . cr fkey? swap drop until 0 cogreset ;
STTS751 is SMBus device.
Prop0 Cog6 ok i2c_detect 0 1 2 3 4 5 6 7 8 9 A B C D E F 00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- 39 -- -- -- -- -- -- <--- STTS751 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- <--- eeprom 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- i2c_device:2 Prop0 Cog6 ok chipID Product ID:0 ManufactureID:h53 Revision ID:1 Prop0 Cog6 ok disableEVENT RUN 12bit setConfig Prop0 Cog6 ok rdConfig EVENT is enabled Conversion mode 12bits Prop0 Cog6 ok Temp 23 .7500degree 23 .7500degree 23 .7500degree 23 .8175degree 23 .7500degree 24 .2500degree 24 .8175degree 24 .7500degree 24 .2500degree 24 .1250degree Prop0 Cog6 ok
Any ideas ?
Sven
I don't have idea about GPS.
I upload SerialCommunication documents to Github.
The only tricky bit is that the number we supply for baud rate gets multiplied by 4 (to allow a higher max baud rate without reworking the kernel)
so to have baud 4800 using caskz's code you would change the line to :
c" 26 27 d1200 serial" 5 cogx
When PID-operating finish, PropForth don't reply prompt.
I made FET-drive curcuit board and Photo-interupt sensor board.
I put capatitor in 12V.
This is caused by hardware or code?
Prop0 Cog6 ok 1200 200 50 10 PID_1 1200 0 1080000 1080000 1080000 2731440 1200 0 1080000 2160000 0 3256800 1200 0 1080000 3240000 0 3782080 1200 0 1080000 4320000 0 4000000 1200 0 1080000 5400000 0 4000000 1200 0 1080000 6480000 0 4000000 1200 628 514800 6994800 -565200 4000000 1200 846 318600 7313400 -196200 4000000 1200 846 318600 7632000 0 4000000 1200 1000 180000 7812000 -138600 4000000 1200 1122 70200 7882200 -109800 3977120 1200 1224 -21600 7860600 -91800 3779120 1200 1390 -171000 7689600 -149400 3390720 1200 1452 -226800 7462800 -55800 3166400 1200 1498 -268200 7194600 -41400 2951360 1200 1536 -302400 6892200 -34200 2734480 1200 1590 -351000 6541200 -48600 2464480 1200 1598 -358200 6183000 -7200 2275520 1200 1608 -367200 5815800 -9000 2078560 1200 1620 -378000 5437800 -10800 1872640 1200 1610 -369000 5068800 9000 1711520 1200 1600 -360000 4708800 9000 1554800 1200 1586 -347400 4361400 12600 1411600 1200 1568 -331200 4030200 16200 1283600 1200 1550 -315000 3715200 16200 1163520 1200 1518 -286200 3429000 28800 1083120 1200 1498 -268200 3160800 18000 989440 1200 1472 -244800 2916000 23400 918160 1200 1446 -221400 2694600 23400 858320 1200 1418 -196200 2498400 25200 814320 1200 1364 -147600 2350800 48600 841840 1200 1340 -126000 2224800 21600 824640 1200 1312 -100800 2124000 25200 827120 1200 1288 -79200 2044800 21600 832720 1200 1266 -59400 1985400 19800 844240 1200 1242 -37800 1947600 21600 870000 1200 1220 -18000 1929600 19800 901680 1200 1198 1800 1931400 19800 943040 1200 1180 18000 1949400 16200 984880 1200 1164 32400 1981800 14400 1030080 1200 1152 43200 2025000 10800 1073120 1200 1142 52200 2077200 9000 1116880 1200 1132 61200 2138400 9000 1165040 1200 1126 66600 2205000 5400 1208480 1200 1124 68400 2273400 1800 1245440 1200 1124 68400 2341800 0 1278720 1200 1124 68400 2410200 0 1312000 1200 1124 68400 2478600 0 1345200 1200 1122 70200 2548800 1800 1383040 1200 1128 64800 2613600 -5400 1403520 1200 1136 57600 2671200 -7200 1416880 1200 1142 52200 2723400 -5400 1431200 1200 1144 50400 2773800 -1800 1452080 1200 1146 48600 2822400 -1800 1472000 1200 1154 41400 2863800 -7200 1477440 1200 1164 32400 2896200 -9000 1474800 1200 1174 23400 2919600 -9000 1467840 1200 1180 18000 2937600 -5400 1465520 1200 1184 14400 2952000 -3600 1465200 1200 1188 10800 2962800 -3600 1463040 1200 1188 10800 2973600 0 1468320 1200 1188 10800 2984400 0 1473600 1200 1188 10800 2995200 0 1478800 1200 1188 10800 3006000 0 1484080 1200 1188 10800 3016800 0 1489360 1200 1188 10800 3027600 0 1494560 1200 1188 10800 3038400 0 1499840 1200 1188 10800 3049200 0 1505120 1200 1190 9000 3058200 -1800 1505760 1200 1192 7200 3065400 -1800 1505600 1200 1196 3600 3069000 -3600 1500000 1200 1198 1800 3070800 -1800 1497200 1200 1200 0 3070800 -1800 1493520 1200 1204 -3600 3067200 -3600 1484400 1200 1204 -3600 3063600 0 1482720 1200 1206 -5400 3058200 -1800 1476400 1200 1206 -5400 3052800 0 1473760 1200 1206 -5400 3047400 0 1471120 1200 1206 -5400 3042000 0 1468480 1200 1204 -3600 3038400 1800 1470400 1200 1204 -3600 3034800 0 1468640 1200 1202 -1800 3033000 1800 1471440 1200 1202 -1800 3031200 0 1470640 CON:Prop0 Cog0 RESET - last status: 0 ok <-- No prompt although hitting any key.
fl { PID Excersize (Using 12VDC-FAN 2500rpm) PropForth5.5 PWM control curcuit 12V 12V | | | 12VDC-FAN 10kohm | 12V | D | |--------G MOSFET 2N7002 10kohm | S | C | |------B | | E | C | | 12V P0 -----1kohm---B | | | E | | 10uF 50V | | | | GND GND GND GND 2SC1815(NPN-Tr) x2 PhotoInterupt Sensor curcuit 3V3 3V3 | | 100ohm 10kohm | | ------- --------------------P1 | | Anode Collector RPR220 Cathode Emitter | | ------- ---------- | | GND GND 2016/01/17 19:39:25 } \ ------------------------------------------------------- \ Constants \ ------------------------------------------------------- \ Special register h1F8 wconstant ctra h1F9 wconstant ctrb h1FA wconstant frqa h1FB wconstant frqb h1FC wconstant phsa h1FD wconstant phsb 0 wconstant _pwm 1 wconstant _sense d80000 constant pwmMax d20000 constant pwmMin \ Time during 1-rotation of DC12V-FAN variable T d900 wconstant scale \ ------------------------------------------------------- \ Variables \ ------------------------------------------------------- wvariable Kp wvariable Ki wvariable Kd variable scaleSP variable scaleCP variable error variable errSum variable lastErr variable dErr variable output variable pwmValue \ ------------------------------------------------------- \ Main \ ------------------------------------------------------- \ ---------------- Measurement for FAN's RPM ----------------------------------------- \ Get state of _sense \ ( -- n1 ) n1:t/f : senseState 1 _sense lshift ina COG@ and ; \ Measure rotation time by PhotoInterrupt sensor \ ( -- ) : 1rotT 1 frqa COG! 1 frqb COG! h20000000 _sense or ctra COG! \ POS detector h30000000 _sense or ctrb COG! \ NEG detector \ Wait until _sense reach to high begin senseState until 0 phsb COG! \ Clear phsa (low-pulse counter) begin \ Wait until _sense become low begin senseState 0= until phsa COG@ \ Read hi-pulse ticks 0 phsa COG! \ Clear phsa (Hi-pulse counter) \ Wait until _sense reach to hi begin senseState until phsb COG@ \ Read lo-pulse ticks 0 phsb COG! \ Clear phsb (lo-pulse counter) + \ Hi-pulse + Lo-pulse T L! 0 until ; \ PID introduction \ ( n1 n2 n3 n4 -- ) n1:setpoint n2:kd n3:ki n4:kp : PID_1 Kp W! Ki W! Kd W! scale * scaleSP L! \ 0 error L! 0 errSum L! 0 lasterr L! 0 T L! _pwm pinout 1 frqa COG! 0 phsa COG! \ Set PWM/NCO mode on servo pin _pwm h10000000 or ctra COG! 0 pwmValue L! c" 1rotT" 0 cogx cnt COG@ d4000000 + \ cnt + 50msec begin \ Get rpm T L@ dup \ Get ticks for 1rotation if d30 clkfreq u* swap u/ 2 u* \ (30sec_ticks/1rotation_ticks) * 2 then scale * scaleCP L! \ Get scales current position scaleSP L@ scaleCP L@ - dup error L! \ error errSum L@ + errSum L! \ error sum error L@ lastErr L@ - dErr L! \ dErr Kp W@ error L@ * Ki W@ errSum L@ * Kd W@ dErr L@ * + + scale W@ / \ Get output \ Convert output to pwm d80 * \ 1usec dup 0< if drop 0 \ If minus, set 0 else dup d4000000 > if drop d4000000 \ If more than d4000000, set d4000000 thens dup \ Set negative value to phsa negate phsa COG! pwmValue L! error L@ lasterr L@ - dErr L! error L@ lasterr L! scaleSP L@ scale / . scaleCP L@ scale / . error L@ . errSum L@ . dErr L@ . pwmValue L@ . cr d4000000 waitcnt \ cnt + 50msec 0 phsa COG! fkey? swap drop until drop 0 cogreset 0 ctra COG! ; \ 1200 200 50 10 PID_1
Drawing graph by sending data from PropForth to Processing.
What is random reset?
You try PID_test.f inside PID1_Exercize on github?
Position get from encoder by connecting motor and it.
fl { PropForth 5.5(DevKernel) i2c_encoder by using 8bit I/O Expander(PCF8574) 2016/03/18 12:50:01 Propeller PCF8574 module 3.3V ------- Vcc Vcc GND ------- GND | P29(SDA) ------- SDA 10kohm P28(SCL) ------- SCL | A ----------- P0 -----------| Rotary | GND ----| Encorder | P1 -----------| | A2=A1=A0=GND | B ----------- 10kohm | Vcc prev current status 0 0 stop 0 0 1 CW 1 0 2 CCW -1 0 3 invalid(=stop) 0 4 0 CCW -1 4 1 stop 0 4 2 invalid(=stop) 0 4 3 CW 1 8 0 CW 1 8 1 invalid(=stop) 0 8 2 stop 0 8 3 CCW -1 C 0 invalid(=stop) 0 C 1 CCW -1 C 2 CW 1 C 3 stop 0 } \ =========================================================================== \ Constants \ =========================================================================== \ Slave addres h20 for PCF8574 h40 wconstant PCF8574 \ A2=A1=A0=0 0 wconstant addr variable encoder_tbl -4 allot 0 l, 1 l, -1 l, 0 l, -1 l, 0 l, 0 l, 1 l, 1 l, 0 l, 0 l, -1 l, 0 l, -1 l, 1 l, 0 l, \ =========================================================================== \ Variables \ =========================================================================== variable pos wvariable prev \ =========================================================================== \ Main \ =========================================================================== \ --- i2c ------------------------------------------------------------------- : err_msg ." I2C error" ; \ If error, print message \ ( n1 -- ) n1:t/f : err? if err_msg cr then ; \ Start i2c-commnication \ This also can use SMBus device. \ ( -- ) lockdict create _eestart forthentry $C_a_lxasm w, h122 h113 1- tuck - h9 lshift or here W@ alignl h10 lshift or l, z1[ixnW l, z1[ixnX l, z2WyP[U l, z20iPak l, z3ryPW0 l, z1bixnW l, z2WyP[V l, z20iPak l, z3ryPW0 l, z1bixnX l, z1SV01X l, zl0 l, zCW l, zW0000 l, zG0000 l, freedict \ Re-defined RepeatedStart \ ( -- ) : Sr _eestart ; \ Stop i2c-commnication \ ( -- ) : _eestop _scli \ Release scl _sdai \ Release sda ; \ _eewrite ( c1 -- t/f ) write c1 to the eeprom, true if there was an error \ Received acknowledge from i2c-device during scl is high \ scl/sda use pull-up resistor at hi \ clock:400kHz lockdict create _eewrite forthentry $C_a_lxasm w, h12C h113 1- tuck - h9 lshift or here W@ alignl h10 lshift or l, z2WyPW8 l, z1YVPQ0 l, z1rixnd l, z1Sy\C] l, z1[ixne l, z1Sy\C] l, z1bixne l, zfyPO1 l, z3[yP[K l, z1[ixnd l, z1Sy\C] l, z1[ixne l, z1Sy\C] l, z1YF\Nl l, z1viPR6 l, z1bixne l, z1Sy\C] l, z1bixnd l, z1SV01X l, z2WyPc7 l, z20iPik l, z3ryPb0 l, z1SV000 l, zW0000 l, zG0000 l, freedict \ _eeread ( t/f -- c1 ) flag should be true is this is the last read \ scl/sda use pull-up resistor at hi \ clock:400kHz lockdict create _eeread forthentry $C_a_lxasm w, h12D h113 1- tuck - h9 lshift or here W@ alignl h10 lshift or l, z2WiPZB l, z2WyPO0 l, z1[ixne l, z2WyPj8 l, z1Sy\Ka l, z1[ixnf l, z1Sy\Ka l, z1XF\Vl l, znyPO1 l, z1bixnf l, z3[yPnN l, z26VPW0 l, z1rixne l, z1Sy\Ka l, z1[ixnf l, z1Sy\Ka l, z1bixnf l, z1bixne l, z1Sy\Ka l, z1SV01X l, z2WyPc9 l, z20iPik l, z3ryPb0 l, z1SV000 l, zW0000 l, zG0000 l, freedict \ Read ports of PCF8574 \ ( -- n1 ) n1:data : rd_PCF8574 \ Start I2C _eestart \ Write slave address[rd], then receive Acknowledge-bit(ACK:Lo NACK:Hi) PCF8574 addr 1 lshift or 1 or _eewrite \ ( t/f ) -1 _eeread \ ( t/f n1 ) \ Stop I2C _eestop swap err? \ ( n1 ) ; \ --------------------------------------------------------------------------- \ Count up/down encorder's position \ ( -- ) : i2c_encorder 0 pos L! 0 prev W! begin rd_PCF8574 3 and dup prev W@ or 4* encoder_tbl + L@ \ Get value pos L@ + pos L! \ Update pos 2 lshift prev W! \ Save prev to shift 2bit left 0 until ; \ Display position with RotaryEncoder without click \ ( -- ) : test1 c" i2c_encorder" 0 cogx 5 delms \ Delay because operating 'encorder' takes a little time. begin pos L@ . d10 delms fkey? swap drop until 0 cogreset ;
fl { PropForth 5.5(DevKernel) i2c_12-KeyPad by using 8bit I/O ExpanderPCAL9554BPW) Using i2c_utility_0.4.1.f 2016/03/21 23:27:26 Propeller PCAL9554BPW SDA ------ SDA SCL ------ SCL ------------------- P0 ------------------| Row1 | P1 ------------------| Row2 12-KeyPad | P2 ------------------| Row3 | P3 ------------------| Column1 | P4 ------------------| Column2 | P5 ------------------| Column3 | P6 ------------------| Column4 | A0 --- GND ------------------- A1 --- GND Row[1..3]:output A2 --- GND column[1..4]:input } \ =========================================================================== \ Constants \ =========================================================================== \ Slave addres h20 for PCAL9554BPW h40 wconstant PCAL9554BPW \ Top pin for 12KeyPad 0 wconstant KeyPad hF KeyPad 3 + lshift constant mKeyPad d4000000 constant 50msec \ register 0 wconstant InPort 1 wconstant OutPort 3 wconstant Config h43 wconstant Pull_u/d_enb h44 wconstant Pull_u/d_sel wvariable key_table -2 allot d10 c, 1 c, 4 c, 7 c, 0 c, 2 c, 5 c, 8 c, d12 c, 3 c, 6 c, 9 c, \ =========================================================================== \ Variables \ =========================================================================== wvariable swState \ current sw-code wvariable lastswState \ last sw-code wvariable debounce variable lastDebounceTime wvariable char variable buffer wvariable pointer \ =========================================================================== \ Main \ =========================================================================== \ Set initial \ ( -- ) : init_sw \ Set initial values 0 swState W! 0 lastDebounceTime L! 0 lastswState W! \ Switch state when no pushing switch 0 debounce W! ; \ Read [Column1..Column4] to drive each Row \ ( -- ) : swScan init_sw begin \ Read current sw and check if pushed or released mKeyPad InPort PCAL9554BPW i2c_rd and 3 rshift \ 4bit-data(Column[1..4]) dup lastswState W@ <> if \ If sw is under debouncong debounce W@ 0= if cnt COG@ lastDebounceTime L! 1 debounce W! then else 0 debounce W! then debounce W@ if cnt COG@ lastDebounceTime L@ - 50msec > if \ Update current swState and lastswState dup swState W! lastswState W! \ Break loop 1 else drop \ Continue loop 0 then else drop \ Break loop 1 then until ; \ Get 1 character \ ( -- ) : get1char \ [P6 P5 P4 P3]=Intput [P2 P1 P0]=output h78 Config PCAL9554BPW i2c_wr \ Set pulldn resistor [P6..P3] 0 Pull_u/d_sel PCAL9554BPW i2c_wr h78 Pull_u/d_enb PCAL9554BPW i2c_wr begin \ Scan 3Rows 1 KeyPad lshift 3 0 do dup OutPort PCAL9554BPW i2c_wr \ Activate each Row-pin \ Read Column-data swScan swState W@ dup if 1 rshift dup 4 = if drop 3 then \ [1 2 4 8] -> [0 1 2 3] i 4 * + key_table + C@ char W! \ Get key-code \ Wait until releasing sw begin swScan swState W@ 0= until else drop then 1 lshift \ Next Row pin loop drop 0 until ; \ Clear charcter buffer : charClr d255 char W! ; \ Print 1 character from 12-KeyPad to TeraTerm \ ( -- ) : demo1 charClr \ Clear char buffer c" get1char" 0 cogx begin char W@ dup d255 <> \ Check if there is key-input if . cr \ Print 1 character charClr \ Clear char buffer else drop then fkey? swap drop until 0 cogreset ; \ Print number to enter charcters from 12-KeyPad \ ( -- ) : demo2 0 buffer L! 0 pointer W! charClr c" get1char" 0 cogx begin char W@ dup d255 <> \ Key input? if dup d10 <> \ Ignore "Cancel" key if dup d12 = \ Check "Enter"key if drop cr buffer L@ . cr 0 buffer L! 0 pointer W! charClr else dup h30 + emit \ Print key input pointer W@ 0= if buffer L! 1 pointer W! else \ Calculate number buffer L@ d10 * + buffer L! pointer W@ 1+ pointer W! then charClr then else drop then else drop then fkey? swap drop until 0 cogreset ;
fl { PropForth 5.5(DevKernel) i2c_JoyStick by PCF8591 Using i2c_utility_0.4.1.f PCF8591_0.3.f 2016/04/05 9:41:37 PCF8591 Propeller AN0 ------- JoyStick Y-axis AN1 ------- JoyStick X-axis AN2 AN3 A0 ------- GND A1 ------- GND A2 ------- GND SDA ------------------------ SDA SCL ------------------------ SCL OSC EXT ------- GND (Selected internal OSC) AGND ------- GND VREF ------- 3.3V AOUT VDD ------- 3.3V } \ =========================================================================== \ Main \ =========================================================================== : JoyStick_demo ." X" 9 emit ." Y" cr begin 0 h44 PCF8591 std_i2c_wr \ Write contril byte 3 PCF8591_rd \ Get A/D-value . 9 emit . cr drop \ drop previous A/D-value d200 delms fkey? swap drop until ;
