Digital recording chip suggestions
Hi All,
I have a project where I would like to record some audio. Essentially it is a old school answering machine for ham radio. The user will hit a couple of DTMF tones and be able to record a short message.
So, used any chips that you liked? Minimum external parts and easy uC control being first, record time and multiple messages second.
Thanks!
Jonathan
Thanks!
Jonathan
The Propeller chip and a ADC chip should be able to do it. It you want to go that route I can post additional info.
Mick, just enough for voice mail. I'm not sure about the exact requirements but I was planning on using the lowest sample rate that the chip has to offer and get the maximum record time out of it.
To be honest, I was thinking of using a PIC for this job. But, if I can use a Prop and skip the voice recording chip, I just might reconsider. It certainly would up the features possibilities. If I need an external ADC to use a Prop that could be a problem as I will be making a dozen or so of these devices, so cost does come into play.
Thanks folks!
Jonathan
Prop + RC ADC + SD = voice recorder
Put an RC on another pin and you can playback audio.
Hmm. That sounds pretty cool. However, it would drive the price up. What is the minimum bit rate that would yield comprehensible audio? If I could get it down, could I use EEPROM to store it? I do like the idea of the SD card for myself and I can see a number of other possibilities that sound fun. But for the run of 12 or so that I need to make I'm not sure if it is a good fit.
Thanks!
Jonathan
So you must have a budget in mind, do your sums, count your costs but be realistic and balanced. Sometimes trying to save a buck each on a run of 12 is applaudable if your weekly income is only $100 but is that so? Otherwise if you spend $12 on fast food then what's a few more bucks?
Well, the Prop and an SD card adds quite a bit to the cost of a unit. So I was trying to see if I can shoe-horn the Prop in there because it would add the possibility for more features. However, it seems that most of the folks just want the basic functions.
I guess everyone here agrees, as there have been no recommendations for recorder chips.
Thanks! I will play with the recording method you describe with a Prop for myself.
Jonathan
There are various of recorder chips around if you search. I use Jameco and they have a few listed. For example:
http://www.jameco.com/1/1/25771-isd1110p-single-chip-voice-record-playback-device.html
http://forums.parallax.com/discussion/105292/parrot-auto-voice-record-and-playback
Yup, totally agree. When I think about what I could buy for the cost of taking the lil lady out for dinner/drinks :-D
I did look over the chip offerings, I was just wondering if anyone has used one that they like. I'll just order a couple and play with them. Bob, the one you linked from Jamco is one of the ones I have looked at, thanks!
These units will be kits assembled by newbies, so no surface mount. A DIP prop is large, making a larger (and more expensive) board. It also needs an external crystal and an EEPROM, more board space and cost. I'm a Prop fan since day one, went to the first release meeting in Rocklin and use them for most of my projects. But they aren't the right fit for everything. And it may be peanut money to you, but some folks have a different definition of that. And it will be quite a bit more expensive than a PIC and a recorder chip by a good margin. On top of that, most of the users of this kit don't want and won't use the added features that would be possible with a Prop. So for them it is just money wasted. For myself, as I indicated, I will be making a Prop powered version.
I am also going to look at using a surface mount Prop and see what I can price it out at. That would keep the board size down. Then I would have to solder the Prop on there for them. Kinda takes a bit away from the kit aspect and then harder to replace if they mess something up.
Thanks!
Jonathan
10 seconds, $1.59 free ship http://www.ebay.com/itm/10s-10-Sec-10secs-Sound-Voice-Audio-Messager-Recordable-Module-Chip-for-Card-/252232288752
30 seconds, $4.51 free ship http://www.ebay.com/itm/30secs-30s-sound-recordable-module-coil-box-messager-for-toy-plush-toy-White-/181337044626
120 seconds, $8.84 shipped http://www.ebay.com/itm/120s-PUSH-BUTTON-RECORDABLE-device-voice-module-music-sound-chip-musical-/230503778631
200 seconds, 11.13 shipped http://www.ebay.com/itm/200s-USB-MP3-LIGHT-ACT-device-voice-music-box-sound-record-chip-module-/260936754424
Hmm. That just might be an idea, because some folks don;t even want the recorder option.
Maybe I should explain the project a little more. Irma, an 80 year old ham, wants to be able to turn off the radio at night but still wants to be there to help if a fellow ham needs help. So, I told her I would build a "long tone zero" detector that would un-squelch her radio if it detects a long tone zero. A long tone zero is the signal of a ham in distress, transmit a DTMF tone zero for ten seconds or so.
Anyway, I built one and it occurred to me that I could add a simple message capability. Hit the right DTMF codes and then leave a message for your pal. Talking about it to local hams, many wanted a long tone zero detector but only a few want the recording capabilities. The kit idea with a class to build them was met with enthusiasm.
For myself, I'm going to make a cool prop version that can handle multiple messages and so on. But most don't want the features. I bet a few will when they get a load of mine though... :-)
Anyway, the external recorder might be a good fit, allows adding it if you want it and ignore it if you don't. Think I'll order one of those to play with too.
Thanks!
Jonathan
I'm suspecting that a Propeller all by itself could do this very nicely. I would use the Prop's sigma delta capabilities as an A/D converter, and a Goertzel transform to detect the DTMF tones, and then use some CVSD (continuously variable slope Delta) modulator in software to do compact audio sampling and storage.
With some tricks, I expect you could get passable audio with as little as 4 kbits per second.... and perhaps if you could add some adaptive algorithm (I have some ideas on that) with only 2 kbits per second.
Such audio files however could only be "played" by a matching reverse algorithm unit, as they would not be standard waveform encodes. And that may not be suitable for you. But if all parties had the same thing, thin that might work.... all in a single Propeller, no extra chips.
Would be a real fun project.
Cheers,
Peter (pjv)
http://www.mcminnarc.com/wilderness.html
I listen to a talknet every now and then and never heard anyone mention this that I can remember.
I have heard of plenty of hams doing other experiments with Raspberry Pis, so that might be an alternate platform. You can get a USB audio interface relatively inexpensively.
If a listener were internet connected, then it could arrange to send an email or text message upon detecting this long tone zero.
@peter - It does sound like fun. I tried to get DTMF decode with a Prop going a while back. If I did get it to work that does save on a decoder chip. I have no experience with audio at all really. I'll look and see what objects are available. I imagine it would be buffered in RAM and you might be able to extend that a bit by writing it to EEPROM as fast as you can. And as long as the Prop can play it back, that is all that is required. However, I am by no means sure my programming skills are up to the task and it would take me a while. The place to start would be recording some audio.
@Kieth - Yeah, that's it. A lot of hams don't seem to know this, not sure why. It's a good way to get attention. Text or email, now there is another idea. I can send email and texts by radio already, so ya never know...
Thanks!
Jonathan
re:. I tried to get DTMF decode with a Prop going a while back. If I did get it to work that does save on a decoder chip.
This object does tone detection.
Go down to Phil Pilgrim (PhiPi) comment:
" Attached is a DTMF input demo I did awhile back that uses the Goertzel algorithm to detect the tones. It includes an Excel worksheet for computing the bandwidth of the filters."
http://forums.parallax.com/discussion/119568/propeller-dtmf
Thanks, I'll take a look at that. For myself, I'm looking at making a unit with a Prop and this radio unit:
http://www.hobbypcb.com/index.php?option=com_virtuemart&view=productdetails&virtuemart_product_id=101&Itemid=425
Still figuring out what to do for the kit. If I get DTMF working, then I'll try my hand a sound recording with a Prop. If THAT works out, maybe the kits can be a prop only solution.
Thanks!
Jonathan
