Propeller DTMF?
Does anyone have an object that can produce DTMF tones for dialing a phone? Also, what is the suggested circuit for this? Thanks in advance.
Micro
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
SX Spinning light display·
http://designedbymemicros.blogspot.com/
Micro
http://forums.parallax.com/showthread.php?p=875553
Good luck
Post Edited (Phil Pilgrim (PhiPi)) : 1/28/2010 7:45:36 PM GMT
I think you are still stuck though needing some 8870 for at least receiving DTMF, if not an 8880 for both sending and receiving.
There is no problem that can't be solved with a suitable amount of explosives!
EOD Memorial
Thanks Phil this should give me the boost I need. I've had a project on paper for some time that needed a DTMF decoder. The problem was all the decoder ICs I could find were obsolete, and hard to find. I figured the Prop could do it but didn't know where to start. Thanks again.
I'm looking for one too!
I tried doing this over the December break and I share what I learned, observed and make some suggestions on what not to do and how to achieve the result.
I was wanting to get one Propeller to generate DTMF and another to listen for it.·I found out about the DTMF generation frequencies in wikipedia http://en.wikipedia.org/wiki/Dtmf·
I thought I'd start with the generation first as that would probably be the easiest part! I tried using the frequency SYNTH object as it would output 2 frequencies per cog - which sounded great for DTMF (which is made from summing two frequencies).·What I found is that the frequency SYNTH object put out a neat squarewave at the right·frequency. I then summed these from two pins via 1K resistors.·Listening to it, it sounded sufficiently close to my human ear to be DTMF, and I seemed to be able to make which ever ones I wanted by mixing the frequencies. To prove that it worked I tried manually·detecting DTMF using the MC14536 DTMF detector chip ·http://www.jaycar.com.au/products_uploaded/MC145436.pdf·However no matter what frequency groups (for DTMF codes) I couldn't detect it. So the question was, is it a problem with the·DTMF generation or the DTMF detection?
To then prove the DTMF·detector was working I then·ratted the box of old phones in the shed until I found one that had a·DTMF generator·chip that I could·find·enough information on to get it to output DTMF when not connected·to the phone line. From there I found that the DTMF detector worked fine.·So the detector was working!
I then·looked at the DTMF from the phone·ong my CRO and it was a couple of very·beautifully formed overlapped sine waves, and not at all like my superimposed·square waves!
I then tried shaping the square waves with inductors and caps to try to round out the edges, but eventually·I gave up after frustration.
I suspect to get the Propeller to output DTMF then we we'll have to generate two nice overlapping sine waves. The start will be to get it to output a sine wave at a defined frequency. I'm guessing we would use a couple of resistors like the composite video DAC, but this will be more complex.
Does anyone out there have a decent sine wave generator?
Dave
JMH
I am working on this project every day so if any one wants to send me a PM I would be more than happy to share what I have learned so far. Its pretty neat.
Alex Burke
"It is not how smart you are rather, it is how you are smart." -Jon Campbell
While both of these would do the job they aren't widely available because I don't think they are in production anymore. Which speaks to my earlier point, honestly if there were newer versions of both DTMF in/out ICs I would be tempted to take the route you did.
Once I wrap up my current project I would love to attack the task of getting the prop to send and receive tones without use of many external chips. This is probably going to be a more difficult task than it appears to be. In fact I know it is. These circuits are pretty finicky and even with dedicated chips it can become very tedious, let me tell you. Generation of tones is the easy part, getting a prop to decode and isolate the tone is a whole nother' bag of worms. I will buy some one a drink if they can create a working DTMF tone encoder/decoder with only a prop and discrete components. It took me a month to get one working with dedicated chips.
Alex Burke
Post Edited (IRobot2) : 1/29/2010 4:12:31 PM GMT
http://www.bgmicro.com/index.asp?PageAction=VIEWPROD&ProdID=10622
