Using the CODE tag in the OBEX textual description and comments???
I have tried all sorts of methods of inserting the <code> tag in the OBEX descriptive and commentary text boxes, to no avail.
It does work fine here in the forums but I cant get it to do anything in the OBEX.
I have tried Text Format "Filtered HTML".
I have tried inserting it into the "Plain Text".
I've tried it with and without a closing tag (eg: <code> </code>).
What am I missing??? Or does it just not work?
It certainly would be nice to be able to use it when explaining sections of source code.
I am certain its probably quite simple... just something I don't know how to do.
Thanks in advance for any help with it here.
(select one of the following:)
nobody cares?
nobody else has had this problem?
I see by indenting the above that [...] [/...]are used here instead of <...> </...> ... just tried and that didn't work either... arg.
Here's some code
And a screenshot...
The OBEX and this forum are separate and different software packages. The forum software includes methods that format text between the [ code ] [ /code ] tags in specific ways. The OBEX does not, it is a repository for code.
Browsers and text editors have different tags and formats.
which is where my confusion comes from...
