display signal strength - xbee & lcd
Hi,
I'm having a bit of trouble getting the signal strength to display on two propellers with xbee's.
I can get everything else to work great, but if i try to place the portion of code that gets the signal strength into my program, it wont work.
using xbee tutorial v1 - page: 67
example code:
Here is the code that I am placing into my program... this is what I isolated from the example code... just a simple display for testing
It just displays "-1" on the LCD.
I'm not sure if it isnt working at all... or maybe it is working and im trying to use an LCD command that only works on decimal values while the received datain value is hex?
Plz help.
J
example code:
* Config_Getting_dB_Level *
* See end of file for terms of use. *
Demonstrates receiving multiple decimal
value with start delimiter
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
' Set pins and Baud rate for XBee comms
XB_Rx = 0 ' XBee DOUT
XB_Tx = 1 ' XBee DIN
XB_Baud = 9600
' Carriage return value
CR = 13
OBJ
XB : "XBee_Object"
Pub Start | DataIn, Val1,Val2
XB.start(XB_Rx, XB_Tx, 0, XB_Baud) ' Initialize comms for XBee
XB.Delay(1000) ' One second delay
' Configure XBee module
XB.Str(String("Configuring XBee...",13))
XB.AT_Init ' Configure for fast AT Command Mode
XB.AT_Config(string("ATD5 4")) ' Send AT command turn off Association LED
XB.str(string("Awaiting Data...")) ' Notify Base
XB.CR
Repeat
DataIn := XB.RxTime(100) ' Wait for byte with timeout
If DataIn == "!" ' Check if delimiter
Val1 := XB.RxDecTime(3000) ' Wait for 1st value with timeout
Val2 := XB.RxDecTime(3000) ' Wait for next value with timeout
If Val2 <> -1 ' If value not received value is -1
XB.CR
XB.Str(string(CR,"Value 1 = ")) ' Display remotely with string
XB.Dec(Val1) ' Decimal value
XB.Str(string(CR,"Value 2 = ")) ' Display remotely
XB.Dec(Val2) ' Decimal value
XB.RxFlush ' Clear buffer
XB.AT_Config(string("ATDB")) ' Request dB Level
DataIn := XB.RxHexTime(200) ' Accept returning hex value
XB.Str(string(13,"dB level = "))' Display remotely
XB.Dec(-DataIn) ' Value as negative decimal
XB.CR
Else
XB.Tx(".") ' Send dot to show actively waiting
Pub Main | datain
LCD.start(TX_PIN, TX_PIN, %1000, 19_200) ' Initialize LCD
XB.start(XB_Rx, XB_Tx, 0, XB_Baud) ' Initialize XBee
Repeat
XB.RxFlush
DataIn := XB.RxHexTime(400) ' Accept returning hex value
LCD.Dec(datain)
waitcnt(clkfreq * 3 + cnt)
Plz help.
J
there was a hint on one of the xbee tutorials working with rssi... "read signal strength from previous data packet"
So I thought maybe the signal strength isnt it's own dedicated send/receive value... rather it is included on each data packet.
II modified my code to first send a basic decimal value, then request rssi.
It works!
repeat ++tmp1 XB.Tx("!") XB.Dec(999) ' send ping, base should reply '999' XB.CR XB.RxFlush DataIn := XB.RxTime(100) If DataIn == "!" ' if start delim received DataIn := XB.RxDecTime(100) ' get ping response If Datain == 999 ' if ping successfully received XB.AT_Config(string("ATDB")) ' Request dB Level DataIn := XB.RxHexTime(400) ' Accept returning hex value LCD.Tx(148) LCD.Str(String("Signal dB = ")) LCD.Tx(160) LCD.Dec(-datain) ' display signal strength else ' if no response received from base LCD.Tx(179) LCD.Str(String("error")) LCD.Tx(188) ' Line 3, Pos 0 LCD.dec(tmp1) ' show counter waitcnt(clkfreq * 3 + cnt) LCD.Tx(179) LCD.Str(String(" ")) ' clear last readingIt worked once... didnt change anything, now im just getting replies of -1
i dont get it... this is more complicated than it should be for such a simple feature
I put this before the repeat loop and it seems to work again
XB.AT_Init ' Configure for fast AT Command Mode XB.AT_Config(string("ATD5 4")) ' Send AT command turn off Association LEDSo I can send receive regular data fine but not rssi... or I can enable AT_init, have rssi reporting working fine but not receive normal data.
So using AT_init goes into command mode? How do I exit command mode?
So I moved the AT-init command.... instead of using it just once before entering my main program loop, I am now using it everytime directly after requesting rssi.
XB.AT_Config(string("ATDB")) ' Request dB Level DataIn := XB.RxHexTime(1000) ' Accept returning hex value LCD.Dec(DataIn) XB.AT_InitOddly enough, this works!
I can send/receive data before sending an rssi request, also after receiving & displaying the rssi data.
I do not understand why this works and would love to know
Love the xbeeProS2 units in AT mode with nothing but the serial driver but would love to get the ATDB working. I had a question though, you said it would kind/some times work. If you type +++ then atdb into your terminal have you EVER got the same value back from atdb in your code?
I did find out that serial.rx would not return the $1F that I would get if I just typed it (+++atdb in the terminal) in but the serial.getc would get the "1" and a 2nd got the "F".
Aside from putc(getc) to debug I have NEVER got ATDB in my code to return the same value as when I type ATDB into the Terminal.
