display signal strength - xbee & lcd
JBWolf
I'm having a bit of trouble getting the signal strength to display on two propellers with xbee's.
I can get everything else to work great, but if i try to place the portion of code that gets the signal strength into my program, it wont work.
using xbee tutorial v1 - page: 67
example code:
Here is the code that I am placing into my program... this is what I isolated from the example code... just a simple display for testing
It just displays "-1" on the LCD.
I'm not sure if it isnt working at all... or maybe it is working and im trying to use an LCD command that only works on decimal values while the received datain value is hex?
Plz help.
J
example code:
{{ *************************************** * Config_Getting_dB_Level * *************************************** * See end of file for terms of use. * *************************************** Demonstrates receiving multiple decimal value with start delimiter }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 ' Set pins and Baud rate for XBee comms XB_Rx = 0 ' XBee DOUT XB_Tx = 1 ' XBee DIN XB_Baud = 9600 ' Carriage return value CR = 13 OBJ XB : "XBee_Object" Pub Start | DataIn, Val1,Val2 XB.start(XB_Rx, XB_Tx, 0, XB_Baud) ' Initialize comms for XBee XB.Delay(1000) ' One second delay ' Configure XBee module XB.Str(String("Configuring XBee...",13)) XB.AT_Init ' Configure for fast AT Command Mode XB.AT_Config(string("ATD5 4")) ' Send AT command turn off Association LED XB.str(string("Awaiting Data...")) ' Notify Base XB.CR Repeat DataIn := XB.RxTime(100) ' Wait for byte with timeout If DataIn == "!" ' Check if delimiter Val1 := XB.RxDecTime(3000) ' Wait for 1st value with timeout Val2 := XB.RxDecTime(3000) ' Wait for next value with timeout If Val2 <> -1 ' If value not received value is -1 XB.CR XB.Str(string(CR,"Value 1 = ")) ' Display remotely with string XB.Dec(Val1) ' Decimal value XB.Str(string(CR,"Value 2 = ")) ' Display remotely XB.Dec(Val2) ' Decimal value XB.RxFlush ' Clear buffer XB.AT_Config(string("ATDB")) ' Request dB Level DataIn := XB.RxHexTime(200) ' Accept returning hex value XB.Str(string(13,"dB level = "))' Display remotely XB.Dec(-DataIn) ' Value as negative decimal XB.CR Else XB.Tx(".") ' Send dot to show actively waiting
Pub Main | datain LCD.start(TX_PIN, TX_PIN, %1000, 19_200) ' Initialize LCD XB.start(XB_Rx, XB_Tx, 0, XB_Baud) ' Initialize XBee XB.AT_Init ' Configure for fast AT Command Mode XB.AT_Config(string("ATD5 4")) ' Send AT command turn off Association LED Repeat XB.RxFlush XB.AT_Config(string("ATDB")) ' Request dB Level DataIn := XB.RxHexTime(400) ' Accept returning hex value LCD.Dec(datain) waitcnt(clkfreq * 3 + cnt)
Plz help.
J
there was a hint on one of the xbee tutorials working with rssi... "read signal strength from previous data packet"
So I thought maybe the signal strength isnt it's own dedicated send/receive value... rather it is included on each data packet.
II modified my code to first send a basic decimal value, then request rssi.
It works!
It worked once... didnt change anything, now im just getting replies of -1
i dont get it... this is more complicated than it should be for such a simple feature
I put this before the repeat loop and it seems to work again
So I can send receive regular data fine but not rssi... or I can enable AT_init, have rssi reporting working fine but not receive normal data.
So using AT_init goes into command mode? How do I exit command mode?
So I moved the AT-init command.... instead of using it just once before entering my main program loop, I am now using it everytime directly after requesting rssi.
Oddly enough, this works!
I can send/receive data before sending an rssi request, also after receiving & displaying the rssi data.
I do not understand why this works and would love to know
Love the xbeeProS2 units in AT mode with nothing but the serial driver but would love to get the ATDB working. I had a question though, you said it would kind/some times work. If you type +++ then atdb into your terminal have you EVER got the same value back from atdb in your code?
I did find out that serial.rx would not return the $1F that I would get if I just typed it (+++atdb in the terminal) in but the serial.getc would get the "1" and a 2nd got the "F".
Aside from putc(getc) to debug I have NEVER got ATDB in my code to return the same value as when I type ATDB into the Terminal.
