Shared smartpins - Pro's and Con's? — Parallax Forums
While playing with the smartpins I realized that it's possible for multiple cogs to fight over the same smartpin.
In this example I have setup a smart pin as an async transmitter and use the same pin from 4 cogs.
The resultant output is "ABCDABCDABCD...".
While I see this sharing could be useful in some modes (measurement) it may cause havoc in others.
Do the smartpins require a "locked to owner cog" control?
Or is this just a simple case of a WARNING in the docs?
'Shared smartpin example - 4 cogs using 1 serial transmitter
	baudrate = 115_200
	tx_pin = 62
dat	org
		pinsetm	a_serial8,#tx_pin	'setup smartpin
		pinsetx	bitclkz,#tx_pin		'set baudrate
		setb	dirb,#tx_pin		'enable smartpin
		loc	adra,#mycode
		setq	##20_000_000		'start delay (1/4 sec)
		coginit	#1,adra			'launch cog
		setq	##40_000_000		'start delay (1/2 sec)
		coginit	#2,adra			'launch cog
		setq	##60_000_000		'start delay (3/4 sec)
		coginit	#3,adra			'launch cog
.loop		waitx	##80_000_000		'wait 1 sec
		pinsety	#"A",#tx_pin		'send "A" character
		jmp	#.loop
bitclkz		long	80_000_000 / baudrate
a_serial8	long	%1_00_11100_0000_0000_00_0_0000000000000
		orgh	$400
		org
mycode		waitx	ptra		'get start delay in ptra
		cogid	adra
		add	adra,#"A"	'generate test chracter
		pinsety	adra,#tx_pin	'send character
		jmp	#.loop
  • ElectrodudeElectrodude Posts: 1,684
    edited 2016-02-13 05:18
    At least something sensible happens. I would have thought that doing that would seriously confuse the smartpins, since I was under the impression that the lines to each smartpins were each OR'd together from each cog.
    What if you add random waitcnts in your loop? Does it still do the same thing? Or does it get misconfigured or confused or locked up or something else bad?
  • jmgjmg Posts: 15,199
    ozpropdev wrote: »
    Good question.
    Depends on what you want to protect against ?
    Present Prop has 'free for all' on Pins, so an errant COG can crash any pin it likes.
    Certainly, there could be merit in a safer mode, where outside code cannot take down a system, but that level of sophistication may be too much for P2 ?
    I think that means you also lock items like PLL, and any other global-access critical control registers.
  • What if you add random waitcnts in your loop? Does it still do the same thing? Or does it get misconfigured or confused or locked up or something else bad?
    It seems to be a case of first in first served.
    No lockup or invalid characters but as expected random output. (BCDBCDBACDBCDBCDBDCBDC)
    I assume some chracaters were lost along the way.
    A note in the doc's is propbaly all that is needed in the end. :)
  • cgraceycgracey Posts: 14,289
    edited 2016-02-13 06:20
    ozpropdev wrote: »
    ...A note in the doc's is propbaly all that is needed in the end. :)
    Yes, I need to outline limitations.
    All cogs can simultaneously do PINGETZ on the same pin, but PINSETx/PINACK to the same pin cannot be from multiple cogs at once.
    ozpropdev wrote: »
    'at once' sounds like it needs expanding ?
    Can multiple COGS can interleave access, viz any time the channel is not busy with another COG ?
  • That by definition is still one COG at a time. Should work, but needs quick test, and debug for potential overlap.
  • Any type of locking mechanism built into the chip restricts experimentation and "feature discovery" and limits forever the implementation of the impossible.
    A caution in the documentation leaves the impossible as a possible achievement with the P2.
    Propellerheads like to achieve the impossible!! :D
