Cant find propeller mini
Dear forum users
When I want to detect my propeller board in the propeller tool.I get a error that it can not find my propeller on com 6. But after the driver installation I can see an ftdi chip on com6
Has some one had the same issue?
Whit best regards Ben
The biggest mistake I always make, is the Propeller Chip is not powered up. The FTDI chip is found, but the Prop needs to be powered also.
The USB connection is for programming only, and does not supply power.
I moved this post to the Propeller 1 forum for you.
The Propeller Mini is based on Propeller 1, so you might get better help from the guys watching that forum category.
All the best.
next question is the propeller 1 5v tollerant?
A translator chip also works, but more money/ real estate.
https://www.adafruit.com/products/395
Thanks for the info guy's
Is it possible to interface a i2c rtc to the propeller?
In the mean time, go to the upper right of the forum page, and type RTS in the search box. That will bring up a few.
Also, the OBEX has RTC objects:
http://obex.parallax.com/search/RTC
Btw the rtc was a example . i whant to interface a holtex led matrix driver But thanks for the help
Now if i get things straight coqs are a propellor equivalent of interupts right?
