Help sending Basic Stamp data over Wifi
in BASIC Stamp
This discussion was created from comments split from: getting a basic stamp to brodcast a webserver.....
I am trying to design a Basic Stamp driven device that will monitor air conditioning condensing unit pressures and temperatures.
Once this data is collected, I need help on how to send via WiFi over the Internet to a central data collection server.
The attached PDF illustrates the reporting sequence. You can click on Analog to Digital Converter, HTML5 Enabled Wireless Module, or Basic Stamp Computer and it will link to various web pages that detail each item.
However, I have no clue how to get the Basic Stamp to send this data. Please advise.
Hi @bbowie !
Welcome the the Parallax Forums!
You posted to an old (2008) thread, so I have moved your question to it's own new thread.
Please feel free to start a new thread with your questions, rather than re-opening older threads.
All the best.
http://forums.parallax.com/discussion/159854/xbee-wifi-send-and-receive-data-from-web
http://www.miupanel.com/en-us/Examples-Products/Arduino-UNO-Examples/Arduino-Basic-Examples
3. WiFi Transceiver connection: connection between the on-board microcontroller and the WiFi transceiver. In normal use, the connection is closed by jumpers. However, user can remove the jumpers and connect cables to communicate with the WiFi transceiver directly. For example, this can upgrade the firmware of the transceiver.
So just remove the jumpers, connect teh TX and RX lines closest to the wifi module to the stamp. However I could not find any mention on teh baud used, but I would start with 115200
