1T/2T SRAM uses 1/5 area of existing 6T designs. Can this help the P2 ??? — Parallax Forums
Here are the details
http://www.zenosemi.com/#!memory-technology/v8i3s
This could be an exciting breakthrough for P2 if it is available and is not too expensive (IP).
  • Seems to be demo at 28nm.
    At some point, if it works it would be licensable IP.
    Would not hold my breath expecting this to be backported to 180nm any time soon.
  • jmgjmg Posts: 15,200
    koehler wrote: »
    That depends on OnSemi, who would need to qualify this on their process.
    The fundamental idea sounds reasonably process-portable, but it would need to be fab'd, tested and tuned.
    Likely would add 6 months+ to P2 delivery.
    Sounds like a good choice for a P2B or P2++, - a respin with more RAM.
    I can't figure out how it works. They say they have proven it at 28nm, though. I wonder if they'd care to take it to 180nm.
    I have asked ;)
    But I bet the IP will be expensive :(
    Maybe they would like to test it at 180nm on the P2 for us ???
    Some reports are saying it might challenge DRAM.
  • evanhevanh Posts: 17,313
    Haven't tried to read any yet but this - http://www.eejournal.com/archives/articles/20160104-zeno/ - will likely be more informative than the script infested Zeno website.
    And these guys - http://www.tezzaron.com/3t-iram/ - are saying the typical 1T-SRAM is as slow as DRAM.
    I think it is similar to the latch-up effect lateral PNP transistors give.
    If you want to avoid refresh, you need more transistors - these guys just claim the cell is smaller, not that the effective transistor count has changed much. They just sneak some extra ones in the same area.
    evanh wrote: »
    Could be true, as lateral / parasitic transistors are never as fast.
  • I believe it's just a variation of the classic Bi-stable Multivibrator in disguise ....
