NewCog Problem
in Propeller 1
The object shown below works. If I change a portion of it to run in a newcog the values returned are wrong.
There are two REMARKS to remove and one to add when changing over to the newcog method. I have played around with sharing data between cogs, this code is not incorporating my lock method. I don't believe the erroneous data is a memory contention issue.
{ The anolog to digital portion is from CD_LTC1298.spin from the OBEX } CON _clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz _xinfreq = 5_000_000 delay = 10_000 CH0 = %1011 ' Note: Shift LSB first so bits are reversed from Datasheet CH1 = %1111 ' Note: See Datasheet MUX Addressing for more details VAR long temp long stack[50] long pitch long yaw byte ADC ' Analog to Digital Channel Din Value. Set using CON values. word pin ' Received PINs from other .spin object word dataio ' Din, Dout Pins - input/output. High impedance protects Dout pin while writing Din word cs ' Chip Enable Pin - output word clk ' Chip Clock Pin - output long datar ' 12 Bit return value from conversion OBJ pst : "Parallax Serial Terminal" PUB Main pst.Start(115200) start waitcnt(700+ cnt) 'cognew(ADC_Stuff,@stack) 'Always returns the value 8191 remove remark when running in a newcog ******** waitcnt(700+ cnt) repeat ADC_Stuff ' Remark this out when running the cognew ************ pst.home pst.Str(@name) pst.newline pst.str(string("Pitch value is..",pst#NL) ) pst.str(string("Yaw value is..",pst#NL) ) pst.Position(17,1) pst.ClearEnd pst.dec(pitch) pst.Position(17,2) pst.ClearEnd pst.dec(yaw) pub ADC_stuff 'repeat ' Remove remark when running in a newcog ********* pitch:= convert(0) delay_us(2) yaw:= convert(1) delay_us(2) PUB start pin := 0 init(pin, pin+1, pin+2) Pub init( cs_, clk_, dataio_ ) cs := cs_ clk := clk_ dataio := dataio_ dira[clk] := 1 ' set clk pin to output outa[clk] := 0 ' Set clk to Low dira[cs] := 1 ' set Chip Select to output outa[cs] := 1 ' set Chip Select High Pub convert( ad_chan ) : datar_val if (ad_chan == 0) ADC := CH0 if (ad_chan == 1) ADC := CH1 dira[dataio] := 1 ' Set Din/Dout to output outa[dataio] := 0 ' Set Din (output) Low datar := write(ADC) ' write MUX Address to start conversion for SDC channel (delay needed???) return datar Pub write( cmd ) : datar_val | i datar := 0 ' Clear the data storage LONG outa[cs] := 0 ' set Chip Select Low writeByte( cmd ) ' Write the command to start conversion for X port dira[dataio] := 0 ' set data pin to input delay_us(2) ' Clock delay ' Ok now get the Conversion for this channel repeat i from 12 to 0 ' read 12 bits 11-0 for MSB outa[clk] := 1 ' toggle clk pin High ' delay_us(2) ' Clock delay if ina[dataio] == 1 datar |= |< i ' set bit i HIGH else datar &= !|< i ' set bit i LOW outa[clk] := 0 ' toggle clk pin Low ' delay_us(2) ' Clock delay outa[cs] := 1 ' set Chip Select High return datar Pub writeByte( cmd ) | i repeat i from 0 to 3 ' LTC1298 has 1 start bit and 3 data bits outa[dataio] := cmd ' send LSB bit outa[clk] := 1 ' toggle clk pin High, Chip reads on rising edge. ' delay_us(2) ' Clock delay outa[clk] := 0 ' toggle clk pin Low ' delay_us(2) ' Clock delay cmd >>= 1 ' shift to next bit Pub delay_us( period ) ' CLK HIGH/LOW time = 2µS MIN waitcnt((clkfreq / 100000 * period) + cnt) ' Wait for designated time DAT name byte "string_data",0
