NewCog Problem
in Propeller 1
The object shown below works. If I change a portion of it to run in a newcog the values returned are wrong.
There are two REMARKS to remove and one to add when changing over to the newcog method. I have played around with sharing data between cogs, this code is not incorporating my lock method. I don't believe the erroneous data is a memory contention issue.
The anolog to digital portion is from
CD_LTC1298.spin from the OBEX }
CON
_clkmode = xtal1 + pll16x 'Standard clock mode * crystal frequency = 80 MHz
_xinfreq = 5_000_000
delay = 10_000
CH0 = %1011 ' Note: Shift LSB first so bits are reversed from Datasheet
CH1 = %1111 ' Note: See Datasheet MUX Addressing for more details
VAR
long temp
long stack[50]
long pitch
long yaw
byte ADC ' Analog to Digital Channel Din Value. Set using CON values.
word pin ' Received PINs from other .spin object
word dataio ' Din, Dout Pins - input/output. High impedance protects Dout pin while writing Din
word cs ' Chip Enable Pin - output
word clk ' Chip Clock Pin - output
long datar ' 12 Bit return value from conversion
OBJ
pst : "Parallax Serial Terminal"
PUB Main
pst.Start(115200)
start
waitcnt(700+ cnt)
'cognew(ADC_Stuff,@stack) 'Always returns the value 8191 remove remark when running in a newcog ********
waitcnt(700+ cnt)
repeat
ADC_Stuff ' Remark this out when running the cognew ************
pst.home
pst.Str(@name)
pst.newline
pst.str(string("Pitch value is..",pst#NL) )
pst.str(string("Yaw value is..",pst#NL) )
pst.Position(17,1)
pst.ClearEnd
pst.dec(pitch)
pst.Position(17,2)
pst.ClearEnd
pst.dec(yaw)
pub ADC_stuff
'repeat ' Remove remark when running in a newcog *********
pitch:= convert(0)
delay_us(2)
yaw:= convert(1)
delay_us(2)
PUB start
pin := 0
init(pin, pin+1, pin+2)
Pub init( cs_, clk_, dataio_ )
cs := cs_
clk := clk_
dataio := dataio_
dira[clk] := 1 ' set clk pin to output
outa[clk] := 0 ' Set clk to Low
dira[cs] := 1 ' set Chip Select to output
outa[cs] := 1 ' set Chip Select High
Pub convert( ad_chan ) : datar_val
if (ad_chan == 0)
ADC := CH0
if (ad_chan == 1)
ADC := CH1
dira[dataio] := 1 ' Set Din/Dout to output
outa[dataio] := 0 ' Set Din (output) Low
datar := write(ADC) ' write MUX Address to start conversion for SDC channel (delay needed???)
return datar
Pub write( cmd ) : datar_val | i
datar := 0 ' Clear the data storage LONG
outa[cs] := 0 ' set Chip Select Low
writeByte( cmd ) ' Write the command to start conversion for X port
dira[dataio] := 0 ' set data pin to input
delay_us(2) ' Clock delay
' Ok now get the Conversion for this channel
repeat i from 12 to 0 ' read 12 bits 11-0 for MSB
outa[clk] := 1 ' toggle clk pin High
' delay_us(2) ' Clock delay
if ina[dataio] == 1
datar |= |< i ' set bit i HIGH
else
datar &= !|< i ' set bit i LOW
outa[clk] := 0 ' toggle clk pin Low
return datar
Pub writeByte( cmd ) | i
repeat i from 0 to 3 ' LTC1298 has 1 start bit and 3 data bits
outa[dataio] := cmd ' send LSB bit
outa[clk] := 1 ' toggle clk pin High, Chip reads on rising edge.
cmd >>= 1 ' shift to next bit
Pub delay_us( period )
' CLK HIGH/LOW time = 2µS MIN
waitcnt((clkfreq / 100000 * period) + cnt) ' Wait for designated time
DAT
name byte "string_data",0
