Reflow Oven recommendation.
JohnR2010
I'm to the point I need to just buy a nice oven but I want to keep it within budget. I found this T962 on Ebay or $172.
Does anyone have input on this oven or another one close in price?
Uneven heat and burns parts,
if you have production run you may get it to work after you dialed in the right temp and time after the 3rd try.
I needs a heat diffuser as IR light is just blaring down on the parts, I looking for some metal mesh and it may be a good oven after that.
But for now a Black & Decker FC300 Infrawave Countertop Oven is better. (hard to find)
I guess this is why I see so many home grown solutions based on counter top ovens. Wonder if there is anything out there in the $250 to $350 range that wont burn components or leave cool spots.
Also I wonder what the difference is between the T962 and T962A.
Here is another oven from SMT Max the AS-5001 for around $500 wonder if it is any better. Sounds like all infrared ovens can burn boards??
size mainly.
The T962 draw will hold an A5 sheet, the T962A a bit bigger than A4. Although you'd probably not want to completely fill the draw space with actual pcbs!
I've also been using both ovens for some years. Takes a while to get the profiles set up for each board/panel - then they work fine.
Last year I added one of these controllers to one of my ovens, and that made profiling much simpler, and sure improved the consistency:
http://www.estechnical.co.uk/products/reflow-oven-controllers
(But you'd probably also "get there" on the stock oven, if you have the time and patience that I often lack
