PropBasic
Beavis3215
in Propeller 1
How do I get started in PropBasic?
I can recommend Viewport for editing/debugging based on what you are working on. I have yet to try SimpleIDE
However, something's not right with the latest version of Viewport because PropBasic programs won't run.
My version is 4.8.2 which works fine.
Maxwin has already reported the problem to One Robot but there has been no response, possibly because Hanno, the author is not yet back in action following his cycling mishap.
I have a post that explains what needs done, I'll see if I can turn it up.
http://forums.parallax.com/discussion/156252
Bean
Getting the files in the folder ?
Changing the setting on the dialog box ?
It doesn't compile ?
Please give more details...
Bean
http://forums.parallax.com/discussion/149659/propbasic-how-to-use-propbasic-in-simpleide/p1
Bean
http://www.fnarfbargle.com/bst/bstc/Latest/
Bean
Is that the problem ? If not, what happens when you type it in ? Does it not save it ?
Bean
I wish I could help with SimpleIDE but I am very happy with ViewPort because I find the built-in scope and logic analyser to be extremely useful.
I am on the road right now but would be happy to send you copies of source that I have collected. Some good stuff can be found on this forum.
Bean
Some of the limitations noted in that article have been eliminated or changed, consult the changelog for details.
disappointed when the Propeller arrived and couldn’t be programmed in
BASIC. Like me, many of these customers had invested years learning and
working with BASIC, and a good portion of that group had a lot of time
with embedded projects thanks to PBASIC. Now, I’m not being critical.
Spin is okay with me and I’m quite comfortable with it. That said, I’ve been
programming in one form of BASIC or another for almost 30 years, and that
kind-of makes BASIC a little bit hard to give up."
Amen!
I may be a devout BASIC programmer but I have always aimed for the most economical code-size, clock-cycles, development time.
Thank you for the N&V article. A couple of the code examples already helped me out.
I sure hope PropBASIC will be compatible with the P2.
