Serial LCD 20 x 4
in Accessories
Does the Parallax 27979 use a Hitachi HD44780 ?
Also i need the file propeller.h, where can I find it?
2. propellor.h comes with simpleIDE.
Welcome to the forums!
The LCD (QY-2004A0) uses a clone of the the 44780:
http://www.systronix.com/access/Systronix_20x4_lcd_brief_data.pdf
As Tom says, the LCD display you quote uses a serial interface, so no need to know the parallel interfacing.
SimpleIDE can be set up from here:
http://learn.parallax.com/propeller-c-set-simpleide
