Enclosure Heater
xanadu
I have an enclosure that is 2.5' cubic volume. It sits indoors, which is around 70f. I need a heater to keep the inside at 130f. I'd like to use a fan to blow around the air to prevent hot spots. I would like to buy a heater and fan as one unit, then use a Prop to build the thermostat. I'm not ruling out built in thermostats, but they aren't required so either way is fine.
I found this - http://www.omega.com/pptst/FCH-FGC1.html It looks perfect. After a phone call they said it's not deigned to produce temps that high. It doesn't have a built in thermostat so I'm guessing there is some internal limiter. It seems to me a 12v 60 watt heater should be able to reach 130f in a confined space.
Does anyone have a suggestion on something that would be able to maintain 130f in a small space?
Input 12-24v DC, 20 amp max
=< 60mm fan to keep size down
Usage is 2000 hours /yr
Thanks.
Thanks.
edit: ah, 12-24 volt, probably won't find that at a pet store. How about a bunch of big ceramic type resistors?
*edit- Smile. Just read you want 12-24VDC
http://www.ebay.com/sch/i.html?&_nkw=12+volt+spaceheater
also try 12 volt space heater and 12 volt defroster
Another possibility, but would require a bit of hacking, is to modify a cheap hot air soldering/desoldering station.
There are a lot of DC heating elements on ebay That gets plenty hot and has the option to control each element individually.
I've been using a 120vac heat gun for testing, it works very well. Plastic PC fans can take a lot of heat, but not the high setting for very long. The other thing is a heat gun has cool air coming into it. This setup is supposed to recirculate air so it doesn't heat up the room it's in.
I can shed my worries because these guys list very high operating temps. So I have a heating element, and now a fan.
Now I need a thermostat, or make one. This looks nice http://www.omega.com/pptst/CN7800.html
Begin wait for parts.
One or more incadescent light bulbs might do the trick and be the easiest to deploy in a small space. I wonder how 150watt 120volt light bulb might perform on 24vdc. I think it is worth looking into. Also try automotive or motorcycle headlamps. Some actually are a bulb that is inserted into a reflector and produce quite a bit of heat.
- well -
Even his ranting against Windows is annoying, putting him into a enclosure goes honestly to far.
Enjoy!
Great idea, I hadn't given putting the motor on the outside much thought. I hope it doesn't take much heat/watts, it doesn't seem to me like it would.
A lot of the food safe heaters were light bulbs. I've noticed them in restaurants but never gave it much thought. I'm going to try some of the eBay heaters because I got a little order happy.
Also I used Rick's suggestion with the resistor, for testing my ability to code a decent thermostat. I taped a thermal sensor to the resistor and pointed a fan at them both in a smaller insulated box. It's a fun experience for someone that doesn't often dabble in that kind of thing.
This box should be a lot of fun. I'm going to shoot some time-lapse involving the effect of heat over time on an object(s).
The heating element from a hair drier can probably be shortened to make up for the voltage change from 120 to 12V, and most all of them have a bi-metal safety switch for over-temp protection.
http://www.ebay.com/sch/i.html?_nkw=100+watt+resistor
Actually, I came up with the light bulbs because that is a common solution of hatching chicken eggs.... they need to stay warm.
This would be fun to have
Speakers actually are not a flat 8 ohm across their entire response range. So in bench testing performance of a stereo amp, dummy loads sometimes are used to see what the amps linear response is over the whole audio range.
I picked up ten 10 ohm 25 watt flame-proof resistors from Fry's. 5% tolerance but close enough, in parallel I should have 1 ohm, it ended up being 0.91 ohm. The good news is that I'm well under 25 watts per resistor, and 40 degrees c below max rated temp. We're well within my target 12 V and 20 A max too. The peak current was 14 A at 100% duty.
Next I have to choose a FET (300w?) and a temp sensor. I'm looking forward to writing the controller code on the Propeller.
Once all of that is done and working I will buy an equivalent PTC heating element and see how much more efficient it is, and have something a lot nicer looking.
Here are some pics of my test heater. I need a bigger heat sink for the top.
This will take 1 cu ft of air 70f to 130f in 9 minutes
Gallon paint can + gallon oil + resistor + coax connector = DIY dummy load!
Now are there trans fats in transformer oil?
http://www.kb6nu.com/be-careful-with-old-dummy-loads/
Jonathan
I told them already but they will do it anyway - http://forums.parallax.com/discussion/comment/1356343/#Comment_1356343
Back to the topic, there are also infrared incandescent light bulbs, build to produce heat not light.
I've been trying to work in a pun about you.
Thanks. I ordered an LC meter for $30 on eBay so I could figure out the inductance of the dummy loads. It should be here soon. I would like to make some more dummy loads because it's actually kind of fun, and rarely do I work with more than a couple amps.
I had thought about that. I'd rather have the hot air radiate from the heater. With the IR you have to heat a surface which then heats the air right?
Still waiting for my giant 300w MOSFET to arrive. I need to figure out the rest of that circuit too. I'd like a nice smooth power draw while using PWM.
Jonathan
