Using Ds1302 with an LCD
in Propeller 1
I need help getting these two components to work together using spin.
my ds1302 I got is pre built with the crystal and backup battery the pins are
VCC
grnd
CLK
DAT
RST
If anyone has sample code using a ds 1302 as well as the parallax Lcd screen on propeller spin it woul be appreciated.
Thanks.
VCC
grnd
CLK
DAT
RST
Thanks.
Sounds like a good project; enjoy.
what is the object labeled DS1302 you are using?
It's normal to archive the project with File>Archive>Project so all the supporting files are included.
Also archiving make the process go a lot faster, ie, not making someone to go to the OBEX, (if they know what that is). The Archive process just makes it so easy peasey.
_mike
Mike, could you archive that project for the Original Poster please.? I don't have it handy.
_mike
