HELP is the High level assembler Essentially Like Pasm. *** Please moderator, move some messages — Parallax Forums
*** Please moderator, would you kindly move some messages from two threads to this one. Thank you ***
First thread, from this post:
forums.parallax.com/discussion/comment/1351233/#Comment_1351233
Second thread, from post:
forums.parallax.com/discussion/comment/1353929/#Comment_1353929
This post is about HELP, which is my working title for a "High level assembler Essentially Like Pasm". It has come about from comments exchanged mainly between jmg and myself, and some of my own ideas and additional reading.
HELP is a preprocessor for PNut which will support GAS style macros. It will also support C style constructs and may even generate unoptimised C code. Have to see how far we get.
  • jmgjmg Posts: 15,194
    You can paste them in here yourself, with quotes in a few separate posts, if that makes things clearer..
    or, give moderators explicit post-range numbers, if you want to move a number of them ?
    ie above you may be meaning 'starting from post#'
  • jmg wrote: »
    Indeed , I could. I will perhaps clarify the first post if necessary.
