Example Software
                                  in Propeller 2
                    I know some of you are developing some software to test / support / explore / demonstrate the P2, but unsure as to the extent or area. To avoid duplicate effort, I would like to lay claim to a pre-emptive multithreaded multicog (code wise) demonstration, that is if nobody is currently undertaking such a task. I would like to undertake this once I have finished the rdlong / wrlong, etc, testing, which is progressing nicely. I am also happy to maintain a list of these packages from a forum post, even this one, linking to your posts in this first comment. This would help direct people to the appropriate place for a given field of interest.
I fully laud your intent in this direction as I have the same interest.
As you may (or not) know, I have over the years developed such a scheme for the P1, allowing some 8 simultaneous threads to run in each cog. In fact, for trivial "led blinking" tasks, I have had over 100 simultaneous threads running in one chip. A task switch takes about 1 to 2 uSec, depending on how many threads a cog has.... 8 is a practical maximum.
All works very well, and with the enhanced capabilities of the P2, I expect to regurgitate and enhance that software to make considerable speed and other performance improvements.
At this point I have not yet embraced developing with the P2 while everything is still in such a change in flux, but I'm getting closer. Perhaps when all the dust has settled on the instruction set, and there is stable documentation and some understanding of the SmartPin capabilities will be my time.
Could be soon, I hope. In the mean time I will follow your development with eagerness, and see how closely your design aligns with my P1 experience. I'm sure I will learn a bunch.
Good on you!
Cheers,
Peter (pjv)
Although I am a recent poster I have been reading the development of the P2 off and on over the past 6 or 7 years, and dipping into the other forums. It is possible I have seen your posts over the years, or they may have been during a period my reading here was light, for one reason or another. Do you recall the thread title or approx month / year?
I think the P2 is easily capable of re-entrant code, especially in the hub-exec mode. Execution and a stack in hub ram may be slower, but it allows for function local variables on the stack. I already have a simple piece of code which manages to look elegant. Fortunately PNut permits immediate constants to define stack offsets: Local constants would be handy, or an ability to undefine (can unconstant? (nuke) ) them, but I think I will manage even with abbreviated names.
The main problem with multithreading is the number of 'CPU' registers which require saving for context. Writing your own demonstration you get to choose how the registers are allocated. If the 'kernel' is included as part of say C, then you are locked in to how ever many registers the software and the porting team implement . That is what will take the time. Though we have the luxury of much more ram to play with.
For my demo I was thinking of using a very simple priorty which can be boosted for more slices, and however many threads it takes to give a simple and good demo to show what is possible. Hopefully someone will build on it in the future. I also intend to use Parallax Serial Terminal with the demo, or possibly converting the output so standard ANSI escape sequences can be generated for updating screen positions for use with putty or similar.
The other aspect or the mt demo is to show reentrancy in hub code, not just from 16 cogs, but perhaps 16 threads
Hopefully this demo can then lead onto a Propeller 2 port of FreeRTOS, just so Parallax can say, "We really didn't need to do this, we were quite happy with sixteen processors running parallel threading natively! FreeRTOS was there looking lonely so we felt we ought to." I have looked at the device dependent sections some years ago for adding in x86 real mode FPU context save but I never got round to submitting it. I doubt that section of code will have changed much.
I think it could be useful for driving control panel displays were each instrument or small cluster has it's own task. The outputs of which are handled either by another task or a non-interruptible driver as necessary.
You have managed to implement mt on a Propeller 1, I now challenge you to write a cog emulator which resides in the cog. Why, you might ask. Well so that you can interpret pasm bitcode. This will allow you to run SPIN as a task, meaning you may be able to have multiple SPIN interpreters running in a single cog, executing more code. Go on, you know you want to do it.
Just to be clear, the multi threading I have done with the P1 is co-operative, NOT pre-emptive as you are planning to do. The development is ongoing, adding Spin friendly features that cause "soft" interrupts in the cog codes.
I have not published much about this, just the occasional reference to what is possible when multi tasking rears its head. There is a REAL early version published years ago on the Parallax site where it was a winner in one of the contests.
I hope to release my completed work for non-commercial applications in the near future.
And no, I have no interest in making an emulator.... too many other things.
Cheers,
Peter (pjv)
