Educational robot arm - Page 2 — Parallax Forums
2»
    Sure, but I want to you to move the disks with your ELEV-8...
  • WhitWhit Posts: 4,191
    Nikos 511 steps would wear most people out!
    edited 2015-09-21 19:14
    @Phipi: Two subtleties I just realized from seeing Nikos' pics :
    1) No peg is required, each disk stacks on the previous disk's knob.
    2) Each disk's knob is the same size, so the gripper opening never changes.
    I think the peg adds a bit of dramatic flair, but the disk knob is exactly what I loved about Phil's design too!
    edited 2015-09-21 19:49
    Very nice, Nikos!
    Mine is much slower than one per second. With 9 disks it would take more than a half hour, I'm afraid, and my students would be sleeping, texting or surfing Reddit. :)
  • Wow, that is taking tower of Hanoi to the next level.
    Martin_H wrote: »
    Yup. If PhiPi wasn't such a friggin' genious, I'd accuse him of showing off, especially concerning his OP comment: "I've never built or programmed a robot arm before". :)
    edited 2015-09-22 00:45
    Today was the day: show 'n' tell with the new crop of students. I challenged a volunteer to race the robot arm, using a manual set of disks and pegs. First student barely won; second won handily in about half the time! (Should've put six disks on the student peg! :) )
    Okay, kid, how did you do it? Can you formalize your success with an algorithm? It's gonna be an interesting, fun semester! (Once they've struggled with it, they'll kill me when they see the simple recursive solution.)
    Recursive? Is that a fancy way to say:
    Move the small disk, every other move, in the same direction, and make the only other legal move allowed in between?
    This is a nice video...
    edited 2015-09-22 02:53
    erco wrote:
    Recursive? Is that a fancy way to say: Move the small disk, every other move, in the same direction, and make the only other legal move allowed in between?
    By recursive, I mean that the move method can call itself:
    PUB start
      move(5, 0, 2)
    PUB move(how_many, from_peg, to_peg) | other_peg
      if (how_many == 1)
        Just do it.
      else
        other_peg := 0
        other_peg -= other_peg == from_peg
        other_peg -= other_peg == to_peg
        move(how_many - 1, from_peg, other_peg)
        move(1, from_peg, to_peg)
        move(how_many - 1, other_peg, to_peg)
    Somehow, it just works!
    Phil - Amazing! I have to think about this for a while!
    @PhiPi: Oh, that's very different. I thought recursive was when I kept swearing.
    Phil, are you going to Robothon? That would help sway my decision to attend.
    edited 2015-10-06 21:12
    Phil - went back and looked over the whole thread - didn't realize you had posted the code earlier. This is a brilliantly created solution IMO.
    That is what makes you the Master and me the student! Thanks for sharing.
  • NikosGNikosG Posts: 705
    edited 2015-10-01 16:12
    I'm in then process to create the U-arm with my 3D printer. However I couldn't resist to make some changes in order to make it better.
    So I changed the bearing (I chose one bigger) and some parts, making the kit simpler and stronger. Here are the changes in red circles
    https://dropbox.com/s/wdxvrh481fgk7vc/Nikos_arm_changes.jpg?dl=0
    The changes in more detail here:
    https://dropbox.com/s/9xgo0ser0bl7o8b/Nikos_arm_changes_detail.jpg?dl=0
    edited 2015-10-01 14:06
    Not sure why the images got garbled, but here are the direct links.
    NikosG wrote: »
    https://www.dropbox.com/s/wdxvrh481fgk7vc/Nikos_arm_changes.jpg
    https://www.dropbox.com/s/9xgo0ser0bl7o8b/Nikos_arm_changes_detail.jpg
  • Publison wrote: »
    Not sure why the images got garbled, .....
    Thank you Jim,
    I also fixed my post.
    I just realized that while this uArm gripper (always parallel to the ground) is perfect for this ToH challenge, the fingers would need small projections underneath to pick up the golf tees in the triangle puzzle challenge. That is, to grab a tee behind another tee or between two tees, something small must stick down in between tees. Nothing PhiPi couldn't have figured out on his own!
