SD Card Going Crazy — Parallax Forums
SD Card Going Crazy
I've had this problem before... I can't remember what the solution was. It's driving me crazy though :(
The attached screenshot is the reset command: 0x40 0x00000000 0x95. Immediately preceding the command (you can see the tail end of it) is the power up sequence many times over (24 bits, 128 times).
What the heck causes an SD card to go schizo like this?
    Do you have a 10uF across the power and ground at the socket?
  • It's the DNA board. Not sure
    edited 2015-09-19 13:18
    I see similar behaviour with some brands of SD cards but not SanDisk. Try different brands and see if it still happens. If you bought grey market SanDisk then they might not be SanDisk but you should be able to read the CID fields etc to confirm chip manufacturer as SD (SanDisk) and model.
    EDIT: Here's the info from a 4GB SanDisk
    .CARD
    MFG             03
    OEM             SD
    PID             SD04G
    REV             80
    S/N             71CC.0203
    DATE            2011/11
    CRC             2E
      CSD REGISTER
    *SDHC CARD*
    TACC            100ns
    NSAC            0bps
    TRANS           50MHz
    BLKLEN          512
    SIZE            3781MB
    and here's a card that can cause some problems
    .CARD
    MFG             27
    OEM             PH
    PID             SD04G
    REV             20
    S/N             035E.06B0
    DATE            2011/4
    CRC             66
      CSD REGISTER
    *SDHC CARD*
    TACC            100ns
    NSAC            0bps
    TRANS           50MHz
    BLKLEN          512
    SIZE            3775MB
