SD Card Going Crazy
DavidZemon
in Propeller 1
I've had this problem before... I can't remember what the solution was. It's driving me crazy though
The attached screenshot is the reset command: 0x40 0x00000000 0x95. Immediately preceding the command (you can see the tail end of it) is the power up sequence many times over (24 bits, 128 times).
What the heck causes an SD card to go schizo like this?
EDIT: Here's the info from a 4GB SanDisk
and here's a card that can cause some problems
