PING))) without an LCD
Gary&Loren
Can I Connect a 7-segment LED Displays to show distances? :chip: If I can, could someone help me find a program that I could use?
You need 1 pin for the Ping and 14 pins for the LEDs.
You can see how to connect and program the Ping by studying the BS-2 examples.
You can see how to connect and program the LEDs by studying "What's a Microcontroller?", p/n 28123.
The short answer to your second question is "Probably not". Longer answer: Most of the folks on this forum are very helpful when it comes to helping you find what you need to know to do what you want, but have no particular interest in doing it for you.
https://www.parallax.com/sites/default/files/downloads/28015-PING-BS2-code-v1.4.zip
The LED display documentation isn't as straight forward but my suggestion is just to play around with it and learn how it works. As Tom said most people here will be more than willing to help you learn how to do what you need to but you still need to do it yourself.
Thanks in advance.
Amanda
Amanda, Nuts and Volts is hard to find right now on the Parallax site right now, but if you type nuts and volts in the search menu, (at the Parallax Site) it will give you a list of different volumes to choose from.
