Who's Online?
I see a new feature on the left... Who's Online. But the only user shown is me. Am I the only one online?
No, can't be. Heater. is always on line too. Maybe Ken, you should make him a moderator!
This discussion has been closed.
now it is showing 2 you and me.
Edit: When I first saw Sapphire's post
Edit: Times above are Eastern Daylight
(I'm thinking this feature may need a bit of work)
I do so much like talking to myself
I would hope so at least. Generally there are half a dozen PC's around the world powered up and logged in as me. Just in case I happen to drop by and want to ramble a bit.
(Never mind I found d the settings)
It shows that I'm online
Someone else must be online.
number and being able to see everybody that is signed in.
(Obviously, there's no one to read this, since I'm the only one online.)
I think the issue might be a latency setting that's set too low. IOW, you're only "online" for five seconds after you link to, or refresh, a page.
I think you are right, by refreshing often enough I can catch someone else on the forum.
(had to edit to change the image and found out that it's not that straightforward)
Ray
Ray,
I think it's work in progress.
I'm curious now - where are those opt-out settings ?
Ah, found it : on left menu list, under Home › Profile › Edit Profile
I think the best strategy is to set the latency time to 30 minutes from the last forum click.
Heater would be an excellent moderator, well at least until the first mention of an OS that should not be named arises (:<>}
wait, wait, ah............
Yes, a bit slow to get updates. I think I will go hide.
