Forum Issue: Strange Behaviour of Older Pictures — Parallax Forums
Duane DegnDuane Degn Posts: 10,588
edited 2015-08-08 19:56 in General Discussion
I noticed when I click on a photo in an old forum post, I get a bunch of strange characters.
Here's what the picture looks like from this post.
http://forums.parallax.com/discussion/comment/1065233/#Comment_1065233
I'm going to paste the same photo here to compare how it behaves.
Apparently we can't just paste images into a post anymore. I'll try again.
When I used the "Image" tool, the following was inserted into the post:
{img}http://forums.parallax.com/attachment.php?attachmentid=88515&d=1326377858{/img}
When I select "edit" from the old post I can see the image inserted as:
{IMG}http://forums.parallax.com/attachment.php?attachmentid=88515&d=1326377858{/IMG}
The only difference I can see is the case of the "img" tags.
Edit: Apparently "noparse" isn't one of the BBCodes approved for use. I changed the square brackets to s-brackets.
  • I'm using Chrome on Windows 7.
  • Duane,
    I don't see the same results on WIN7 Chrome. I wish we had post numbers, but I think this is the same post you provide the offending picture from
    1140 x 854 - 561K
    Same problem here. In this post and the original you linked to. Chrome on Debian. Seems to be a mime-type issue.
    edited 2015-08-08 19:44
    Using Chrome Version 44.0.2403.107 m on WIN7 PRO
    Same problem with image shown as text in FireFox on Debian.
    With the added twist that the script on the page times out !
  • I don't see the problem with Safari on OS/X.
  • Just checked with WIN XP Pro Chrome. Not seeing any problems.
    Duane, did you say you only saw this when trying to edit the post?
  • Nevermind, your not going crazy. :)
    I see it when you I click on the image file. Both WIN7 and WIN XP PRO and Chrome.
  • The problem only occurs when I click on the image.
    I get the same behaviour if I'm not logged in.
    I tried clicking on the image with IE8 on my Windows 7 machine and the image opened properly but as the only item in the window. It didn't open in the little picture viewer window.
  • Duane Degn wrote: »
    Same behavior with WIN XP EI8.
  • TorTor Posts: 2,010
    Aha, yes, problems occur on Android if I click on the picture in the thread linked to (if I don't, everything looks normal).
    The Android browser hangs. Must wait until the OS asks me if I want to kill the browser, and answer yes. That's very rare (that it doesn't ever return to the living).
  • I linked this thread to Bump for his input and he has stated he will look into it.
    Adding to the issues list and then sinking.
