Basic Stamp Editor wont't run programs
When I try to run a program, it shows me this:
Port Status: Scanning... Port: Device Type: Version: Loopback: Echo: COM4 Ignore BS1 Modules unless downloading BS1 Source Code Download Status: 0%
Working Now!
Working Now!
Has this setup worked before?Is it a BS-1 or BS-2?Did you change the programming computer?Are you using a serial port or USB-to-Serial converter?If USB, is it USB2 or USB3?
