Forum Issue: Bring back BBCodes
There was a time when I thought allowing raw HTML would be cool. My experience with this forum has significantly tempered that enthusiasm. Bump, can you enable BBCodes here and disable HTML, please? I miss the simplicity of
Thanks,-Phil
and
. Even worse, Heater has identified significant security issues surrounding hidden DIV blocks, which the forum allows.
Thanks,-Phil
but sadly
b) It is broken in the same way, with bogus chars and smileys appearing inside [code]....
http://vanillaforums.org/discussion/30329/getting-erroneous-semicolons-in-code-tags
So, maybe do not jump yet.
I like the sound of markdown, as it supports a language tag in the code-blocks, and syntax highlighting.
The lack of BBCode support has been added to the list of issues.
