Propeller, RFID and a Magnetic Door Lock
I want to install a door lock similar to this one: http://www.ebay.com/itm/12V-Electromagnetic-Door-Locks-Magnetic-Lock-280KG-Holding-Force-Access-Control-/351119037068?pt=LH_DefaultDomain_0&hash=item51c053528c
and control it with a prop and an RFID reader. My question is, what do i need to connect to in order for the propeller to send the signal to the door lock to open when a correct card or key fob has been read.
I wonder if it would be possible to defeat it with an external electromagnet tuned to cancel out the locking magnet's field? It would be hard to do but I'd think it should be possible to measure the magnetic field from the outside of the door and figure out which direction the field was pointing. One could then generate a field in the opposite direction and keep turning it up until the fields cancelled out.
It would probably be easier to just break the door down so I doubt it's anything to worry about.
Specifications:
1.Holding Force: 280Kg
2.Working voltage: DC 12V
3.Weight:1909g
You are going to have to bench test the current draw on your lock before anything can be determined for sure.
Here is an alternative door lock that is quite common in Taiwan. My building has one on the front door and they do hold up quite well. The hidden side will accept a cylinder lock to allow outside access with a key. And this only requires power to open the door, not to hold the door locked. It mounts to the surface on the inside of the door and has a mate for the the door jamb surface. The button on it will mechanically release the door for quick exit. So all the electric portion does is all you to remotely allow someone entry upon request.
www.ecvv.com/product/3421071.html
I can not think of any reason why a magnetic lock is more secure then a actuated bolt. 280 Kg of holding power. Hmm. I am able to push (maybe pull) 280 Kg. When using some leverage like a rope and a block, even more. If power goes down it is open? What a great lock.
Look at car door locks. Able to open with a key and able to used with electricity or vacuum. If all fails they are closed. You need a key. Mechanical bolted and able to sustain forces way over 280 Kg. Think about car accidents.
Not sure what you want to protect against whom. But just relaying on magnetic fore, powered by a wall wart or battery sounds not good to me.
Just my 2 cents
It doesn't mention how much current is uses. It would be too bad if it cost a significant about of money to keep a door locked.
I see kwinn gave an estimate on current draw. If the lock pulled 500mA then it would be drawing 6 Watts of power when activated. Not a huge draw but something to keep in mind.
I agree with Mike on this one.
There's some power specs on similar item, if not the same.
You might want to use a power supply with a limiter in case this thing develops a problem. There's something about a big coil of wire, drawing 1/3 amp, sandwiched in wood...
Is that something good or bad?
These things look really cool but I think Mike made some good points against using one as a door lock.
I'm not so sure about a home install and being on 24/7. I think these mag locks are for doors that are opened and closed frequently, where a mechanical movement would wear out or be too slow.
I don't want to sound negative about it though, I think that it's a fun thing to do, with the right power supply that is.
I think I will get one and overheat it and see what temps it hits for fun, maybe undo some of my paranoia lol...
I wonder if you can get the alignment right with a wooden door as well. Wont the door change shape based on humidity and temps?
This may not work at all on a less "precise" door. Or it might work for awhile then when you need it...
In the schools the main purpose for them was for emergency lockdown and to control access to the school yard during the day (recess and lunch). The card access systems generally used electric strikes that mounted in the frame and they were locked unless power was applied.
The doors were mainly steel clad to allow for sturdy mounting of the mag lock plate. The plate is mounted with one centered bolt and has a guide pin at each end to hold it in place. It can be adjusted by inserting spacer washers on the guide pins before tightening the mounting bolt.
All in all I found it to be a less than satisfactory setup that required frequent adjustment as the doors warped or the building settled. The electric strikes were better, although they had their own issues. I think a solenoid mechanism similar to a deadbolt would be much better but I have not seen anything like that on the market.
One suggestion if you go with the mag lock. Mount the door plate first, making sure it is positioned so that it aligns with the mag lock when it is mounted on the frame. Then close the door, place the mag lock against the door plate and apply power to it. This will hold it in alignment while you drill the holes and mount it.
The lock I mentioned is everywhere in Taiwan. And the few that I have seen fail did so after at least a decade of heavy traffic -- front door to an apartment building with 20 units. It uses more amps, but only as a pulse to release the latch, and can be completely usable when there is no power avaiable -- key entry on one side, button to open on the other.
My gut feeling is to go with a locking system that doesn't require 24/7 power to be active. The electronics will be more reliable. And any lock should have a redundant bypass for emergency access and exit.
Agreed. I keep trying to think of some sort of robotics application for one of these but I have yet to think of a good one.
BTW, The MIFARE 13.56MHz RFID readers (not compatible with the Parallax readers) are all over the place on ebay. They're surprisingly inexpensive. Here's a link to an object I wrote for these inexpensive readers. These readers are nice and small.
Your link doesn't seem to be working. Nothing happens when it is clicked on.
Of course, how would they know if you put one in, It's not like the fire marshal goes around to all the houses and checks. They really only know if you have a claim.
Thanks for letting me know. It's fixed.
Get one of those and either add your RDIF stuff, space provided or remove old electronic and replace by your propeller based version... Get rechargeable batteries or two sliding contacts between door and frame and use a wall wart.
Enjoy!
https://www.sparkfun.com/products/13648
Seems like a pretty easy way of making a deadbolt into an electronic door lock.
Andy, It used to bug me when someone would tell me "you're doing it wrong." But then I realized these are actually the most valuable posts someone can offer (assuming they're correct). As kwinn mentioned, being warned there are better ways to accomplish a task can save a person lots of time and money.
Here are a couple of "You're doing it wrong" posts I've had.
Here's my relay controlled cell phone:
http://forums.parallax.com/showthread.php/133851-Propeller-Cell-Dialer-Texter
This one doesn't really count since I pretty much knew I was doing it the hard way as I was wiring up the relays. Sometimes I get a harebrained notion and just need to try it even though I know it's impractical.
As someone pointed out in the thread, it's a lot easier if one uses a phone or module which can be controlled directly from a microcontroller. Here's my latest attempt to interface a Propeller and a cell phone.
This next one, is a better example. I really thought increasing the size of the rims on my Rover 5 would help keep the treads on.
http://forums.parallax.com/showthread.php/145281-Rover-5-Projects-and-Information?p=1164343&viewfull=1#post1164343
Fortunately erco told me I was doing it wrong. It turns out eliminating the rims was a much better solution than increasing the size of the rims.
Now when someone says "you're doing it wrong," I think "Great! Thanks for saving me a bunch of time and money."
