Controlling ESC with Propeller
I'm controlling 6 ESCs by generating PWM from 6 pins. Like this: https://youtu.be/dpBC2phplTM It abruptly stops as I increase thrust; say, it stops like about 70 % of max thrust. But, if I only increase one motor, the motor's RPM can go higher than 70%. I was wondering why this happens. I first thought the battery matters, but it can't be; battery is 12,000 amh 30C (360A) and ESC's max amp is 20amp, so 6 of them counts for 120A.
So, it would be helpful if someone can verify my second speculation. Does propeller (ASC) need higher voltage(or amp) to support PWM for 6 pins? Does ESC signal receiver somehow absorbs power from propeller chip? (because I'm only powering the chip with usb)
Thanks for reading
Thanks for reading
Which code do you use to create the ESC-input-signal? Servo32 V9?
do you have an oscilloscope to watch the signal or at least a digital multimeter which can measure frequency and duty-cycle?
six 20A ESC sounds like a bigger project. In my Opinion to buy such a mutlimeter would be a good investion
I mean something like this
http://www.amazon.com/UNI-T-Digital-Multimeter-Frequency-Resistance/dp/B00AW6SHNO/ref=sr_1_7?ie=UTF8&qid=1433487542&sr=8-7&keywords=uni-T+multimeter
Specs
Frequency : 10Hz/100Hz/1kHz/10kHz/100kHz/1MHz/10MHz ; ±(0.5%+3)
Duty cycle : 0.1% ~ 99.9%
this no propeller-chip found issue:
If the propeller-chip is booting up is there a certain moment where the prop-chip will not respond to the IDE?
Or will hitting F10 ALWAYS start new booting regardless of what the prop-chip is doing?
best regards
Stefan
One reason for this that I have found is that if the Prop is transmitting a lot of data back to the PC, even if it's garbage, it will clog up the USB FIFO which then upsets the timing of the boot handshake etc. Of course the Prop gets the reset pulse but anything it sends back has to get into the long queue until the IDE gives up. On systems that are locked up like this I ground the SDA line of the EEPROM long enough which might require a second F10 before it responds.
1. I made my own PWM generating object which turned out to be as stupid as me. The pointer of pulse value is somehow doesn't work well. - need to find out soon.
2. I could have used Servo32 library - but I just wanted to have fun with the code
3. Regarding the "not found chip", Peter's reasoning makes sense to me. It was nothing to do with "voltage or amp" of the chip.
So is it solved?
If you post your code, it would help to solve the problem if you have not already solved it.
Thanks.
