MCP3204/MCP3208 Input Resistance Question
                    The current circuit will be used to monitor 2 separate (common ground) battery banks in a vehicle ("12" vdc system).
I'm having a heck of a time making sure I have the optimal input resistance setup for the MCP3204.
My main question is: what are the optimal sized resistors to use for 2 voltage dividers (same voltage ranges) in order to give the proper RC circuit timing with the MCP320x internal sampling capacitor.
From what I understand:
On the fast end, the input resistance needs to be at or under 1K ohms (Including the MCP's internal 1K sampling switch) in order to maintain the max 2 mHz speed.
On the slow end, the MCP becomes inaccurate below 10 kHz due to capacitor leakage/discharge.
I'm happy anywhere in between.
I am also attempting to sync up my time constants a bit on all 4 channels of the MCP3204. 2 channels are used for the voltages, one is used for current, and the last is used for user input switches.
I'm leaning toward replacing the 1k resistors on the ground side of the voltage dividers with 10k resistors and adjusting the R1 resistors accordingly (2.37k becomes 23.7k).
Then adding a 10k resistor inline with the current sensor.
If I did my calculations correctly, this will give me an overall resistance of 7.032k as seen by the ADC input pin.
Here is the schematic and some items from the data sheet.
MCP3204 Resistor Sizing - Schematic - v1.0 .pdf
MCP3204 Resistor Sizing - Notes - v1.0 .pdf
The full Data Sheet can be found here:
http://ww1.microchip.com/downloads/en/devicedoc/21298c.pdf
Thanks!
Scott
Thanks!
Scott
A lower sampling rate will allow the sampling capacitor to charge more fully, and placing a small capacitor (0.1 or 0.01uF) across the 10K resistor between gnd and the input pin will reduce the effective input resistance and help reduce any noise on the input.
