Test Phil's picture posting procedure
Below I hope to see a pic of my bot "Slammer".
[img][/img]http://forums.parallax.com/attachment.php?attachmentid=114382&d=1433123929
Why is there no direct- image post available?
I'll try another picture here and see if I can get it right.
It worked!
Thanks for the interest!
Hal
When we reverted to this old version of the forums, image embedding for posts was lost. We have no current plans to investigate or fix the issue, as a forum rework is pending.
Hello!
Hal, what are we looking at? It looks like a bot named after a fighter aircraft's favorite missile nickname who's supporting his own display.I,mean what exactly makes him special? I mean besides the incredibly obvious.
The photo is from post #1. Tony was just showing how to insert the photo into a post. The photo was originally posted by Hal.
It is indeed. I should have checked that. Thanks and I edited the post to say that and added something else. Oh and that method fixed my display problems for showing Smoky to all of you.
I nicknamed my bot Slammer because of his propensity to "slam" into furniture legs before his sonar array is able to "see" them. Apparently I have not given enough thought and code into obstacle avoidance coupled with the rather narrow sound cone these cheap SR04 units use. My test range is rather fraught with tall, spindly legged plant stands and several old-fashioned rocking chairs, all of which seem to be sonic "black holes", sucking up the pulses rather than reflecting them in a meaningful way. I may need to add two more SR04's to cover the void between the center sensor in front of the display and the two diagonal pointing ones, since this area seems to attract multiple table leg attacks.
