Using Simple IDE without aboard to program
I recently bought the Surface 3 for school and I downloaded Simple IDE so that I could program propellars on the fly. I was wondering however if it were possible for me to use the program without a board and still compile and run programs and use the serial terminal to display characters and such?
You will not be able to run the programs. Neither will the terminal work, it needs as Prop (or other device) to communicate with over serial.
