Using Simple IDE without aboard to program — Parallax Forums
plau45plau45 Posts: 109
edited 2015-05-29 08:26 in Propeller 1
I recently bought the Surface 3 for school and I downloaded Simple IDE so that I could program propellars on the fly. I was wondering however if it were possible for me to use the program without a board and still compile and run programs and use the serial terminal to display characters and such?
    edited 2015-05-29 07:35
    I see no reason why you cannot use SimpleIDE to write and compile programs for the Prop even if you have no Prop.
    You will not be able to run the programs. Neither will the terminal work, it needs as Prop (or other device) to communicate with over serial.
  • plau45plau45 Posts: 109
    edited 2015-05-29 08:19
    Ok. I thought as much but wasn't for sure.
  • yetiyeti Posts: 819
    ...what about Gear or SpinSim?
