I barely touched it! Honest!
Phil Pilgrim (PhiPi)
And this happened:
'Not a big deal, really, as I think it's easily repairable. Here's what I plan to do:
I suppose I could just use solder paste and reflow it in the toaster oven, but I don't want all the other parts to come loose with unforeseen consequences
Other suggestions are welcome...
1. Tin the pads with leaded solder and wick it off, so they're completely flat again.
2. Run a Flux-Pen over the pads.
3. Super-glue the board back together where the glue joint was before, making sure the pads are properly aligned.
4. Heat the pads from the top and add solder through the holes so it, hopefully, wicks through and bonds with the pads below.
But to reiterate the warning in the GPS doc, when it says, "Don't press here," it means it -- not even a little bit.
Thing is, a GPS is bound to be used in applications with vibration. So soldering alone can't be relied on to hold a physically heavy part to a lighter one. I'm going to guess yours didn't have enough edge gluing.
Single edge support as they have done here,is never a good idea..
If it moves and it shouldn't, use duct tape. If it don't move and it should, use WD-40.
If you spent your beer money for the week on WD-40 and duct tape, push it in the garage and call it a "classic"!
I know you said you fixed this, however we would be more than happy to get you a replacement. Send me a PM and I will have one sent out. I let our manufacturing department know about this, but so far we haven't heard of any others with this issue.
Someone beat me to it!
They really should have started from the bottom up for proper overlap direction. Otherwise, it looks not too bad.
As for the guy in the foreground, this isn't the smartest way to hide the getaway car after the fact.
