RTC for Propeller - Page 2 — Parallax Forums
RTC for Propeller
2»
    edited 2015-05-12 14:06
    Yes, you will need to loop at least once per second to ensure that you don't miss the event time.
    EDIT: BTW, when I commented earlier that it should have printed T1 I must have been looking at Ray's version of the code. The original code did not print T1.
  • DiscoveryDiscovery Posts: 609
    edited 2015-05-12 14:25
    Dave...that was the problem.
    I put the Get_Time call into a loop to sample the RTC and compare T1 to s. No match.
    I duplicated Get_Time and modified it to Get_Time2 but removed the print line of code.
    This allowed the loop to run fast enough to make the match.
    Thank you very much...I have it now.
    Discovery
