RTC for Propeller — Parallax Forums
RTC for Propeller
DiscoveryDiscovery Posts: 606
edited 2015-05-12 14:25 in Propeller 1
Is there a "C" code Real Time Clock file available for running on one COG of the 8 COG Propeller chip?
Would it be more accurate than a DS1307?
Sincerely,
Discovery
  • RsadeikaRsadeika Posts: 3,847
    edited 2015-05-10 10:43
    I built this on an example code program that jazzed(Steve Denson) provided many moons ago. I have not run this in quite some time, but IIRC, the program kept a fairly accurate clock. Do with as you please.
    Ray
      softRTC.c
      November 16, 2013
    #include "simpletools.h"
    //#include <time.h>
    #include <sys/rtc.h>
    #define BUFFERLEN 10
    void Help();
    void Set_Clock();
    int getdst();
    int prompttime(char *prompt);
    void Get_Time();
    void Get_Date();
    int main()
      // Add startup code here.
      uint8_t buffer[40];
    //  int DO = 22, CLK = 23, DI = 24, CS = 25;      // SD card pins
    //  sd_mount(DO, CLK, DI, CS);                    // Mount SD card
      _rtc_start_timekeeping_cog(); // <---- important.
      print("This is softRTC\n");
      print("help - for menu\n");
      while(1)
        // Add main loop code here.
        print("> ");
        gets(buffer);
        if(!strcmp(buffer, "quit")) break;
        else if(!strcmp(buffer, "help")) Help();
        else if(!strcmp(buffer, "setclock")) Set_Clock();
        else if(!strcmp(buffer, "time")) Get_Time();
        else if(!strcmp(buffer, "date")) Get_Date();
        else
          print("Invalid Command!\n");
      print("System Stop!\n");
    void Help()
      print("Commands are: setclock, time, date, quit.\n");
    void Set_Clock()
      struct timeval tv;
      struct tm t;
      t.tm_isdst = getdst();
      t.tm_year = prompttime("Year")-1900;
      t.tm_mon = prompttime("Month")-1;
      t.tm_mday = prompttime("Day of the month");
      t.tm_hour = prompttime("Hour");
      t.tm_min = prompttime("Minute");
      t.tm_sec = prompttime("Second");
      tv.tv_sec = mktime(&t);
      settimeofday(&tv, 0);
    int getdst()
      int rc = 0;
      print("Use daylight savings time [y/n] ? ");
      fflush(stdout);
      rc = (getchar() == 'y') ? 1 : 0;
      getchar();
      return rc;
      int rc = 0;
      char *endp;
      char buffer[BUFFERLEN];
      do
        print("Enter %s: ",prompt);
        fflush(stdout);
        fgets(buffer, BUFFERLEN,stdin);
        fflush(stdin);
        rc = strtol(buffer, &endp, 10);
        if(endp == buffer)
          if('\n' == *endp)
            rc = 0;
            break;
          print("Invalid entry \"%c....\" Please enter a number.\n", *endp);
      } while(endp == buffer);
      return rc;
    void Get_Time()
      char timebuff[16];
      time_t now = 0;
      now = time(&now);
      strftime(timebuff,16,"%T",localtime(&now));
      print("%s\n",timebuff);
    void Get_Date()
      char timebuff[16];
      time_t now = 0;
      now = time(&now);
      strftime(timebuff,16,"%b %d, %Y",localtime(&now));
  • DiscoveryDiscovery Posts: 606
    edited 2015-05-10 16:11
    Thank you...
    The clock is running and I established an accuracy test.
    Sincerely,
    Discovery
    edited 2015-05-11 07:15
    I want to use the time and date generated in the RTC COG to start and stop events.
    How would you use the Code to detect 13 hours, 20 minutes, and 16 seconds?
    Sincerely,
    Discovery
    edited 2015-05-11 09:07
    For that, my friend, you will have to use your C programming skills. I would start by looking at the Get_Time() and Get_Date() functions for some ideas. jazzed does not come around here that often so, you will have to do the hard work. Since their are C programmers here, I would suggest you showing some of your own code, and then maybe somebody might give an idea if you are going in the right direction. You also might want to do a 'time()' search on the internet and see what that brings up.
    Ray
    edited 2015-05-11 10:22
    Oh boy...
    My "C" programming skills are not very good.
    It is too bad that Jazzed cannot take a whak at solving the problem...chances are he would know precisely what to do.
    Sincerely,
    Discovery
    edited 2015-05-11 10:35
    Discovery wrote: »
    Sincerely,
    Discovery
    Of course it would be tied to the accuracy of the crystal on both platforms. 10PPM is normal for both if you are using off the shelf crystal for the DS or the Propeller. There are more precise crystals available :
    http://www.mouser.com/Passive-Components/Frequency-Control-Timing-Devices/Oscillators/TCXO-Oscillators/_/N-7jdmj
    edited 2015-05-11 10:36
    If you are waiting for somebody to do the work for you, you will probably be waiting a very long time. Go with what you know, if Spin is your strong suit, then look up some softRTC programs in the OBEX, other than that, not sure what will help you.
    Ray
    edited 2015-05-11 11:03
    Discovery wrote: »
    Sincerely,
    Discovery
    If you are only worried about the time of day, you can get that by get the modulus of 86400, which is the number of seconds in the day. You could then convert the target time to seconds using "hour*3600 + minutes*60 + seconds", so 13:20:16 would be 13*3600 + 20*60 + 16 = 48016.
  • wned57wned57 Posts: 5
    edited 2015-05-11 11:27
    Dave Hein wrote: »
    HA! Thanks, Dave. That takes care of that. I stumbled into this thread checking out something else entirely, now I've got the answer to a question I didn't even have to ask!
    edited 2015-05-11 12:00
    In the Code that Ray posted above...the Get_Time() function should be the point to extract the time.
    void Get_Time()
    char timebuff[16];
    time_t now = 0;
    now = time(&now);
    I figured that timebuff would be the char string that would do the trick since it is used as the printed variable.
    Using
    static volatile char s;
    in my definations I figured that putting
    s = timebuff;
    command into the Get_Time() function would make it available in the main COG. But when I print it in the main COG...it is empty.
    What's wrong?
    Discovery
    edited 2015-05-11 12:38
    All of the code runs in the main cog, except for a small amount of library code that counts every time the system counter wraps around. You can move the declaration of timebuff out of the Get_Time routine to make it available to other routines. This will also move it off of the stack.
    If you want to use s to hold the address of timebuf you need to declare it as a char pointer, and not just char. If just declared as a char, s will only hold the least significant byte of the address of timebuf. So s should be declared as "char *s". Note that timebuff must still be declared as static or declare outside of the Get_Time routine to move it off of the stack.
    When you build the code you should look at the warnings that are generated. Declaring s as a char and then storing the address of timebuff to s should have generated a warning message from the compiler.
    edited 2015-05-11 12:49
    Thank you Dave...I will get on it.
    Sincerely,
    Discovery
    edited 2015-05-11 13:11
    @Discovery, not sure what your intentions are with this, but a brief overview of what I was going for. When I started this program, it was going to be a base for my mobile temperature/humidity data logger, as a start.
    The project was going to use an AB, sht11 module, XBee module, and be powered by some batteries( or power pack). After adding the code necessary for accessing the SD card, sht11 module, XBee module, and the softRTC, using CMM, I only had something like 2K of memory left to work with, as I recall. That does not include code for starting and stopping events which would be running in their own cogs. Plus expanding the project to include some CO2 sensors, amongst other things was out of the question.
    So, you just may want to be sure if you are using the correct equipment and tools before you get too far into a project. Lessons learned the hard way.
    Ray
    edited 2015-05-11 13:42
    Hi Ray,
    My application is really simple. All I want is a RTC that I can access in a loop that will compare the hour, minutes, and seconds from the RTC to a short list of start times. When there is a match, a pump turns on for a certain number of minutes.
    Dave,
    I made changes you suggested, character pointer and inside the function declaration and outside. The problem persists...can not gain access to timebuff that should have the result of Get_ Time.
    Would it be simpler to use someone's existing propeller code that interfaces to a DS1307?
    Discovery
    edited 2015-05-11 13:53
    Do you have access to a program that does that already? What language will you be using? If you are using Spin, you still have to know how to manipulate the values that you pull from the DS1307 module.
    Ray
    edited 2015-05-11 13:58
    The soft RTC is about as simple as it gets. Post your code and we should be able to figure out what's wrong.
    edited 2015-05-11 14:46
    The program code is attached. The problem resides in what would be the second WHILE loop but for problem solving...I am trying to get access to the time from the SoftRTC so that the RTC time can be compared with a list of times which the program will use to initiate processes.
    Discovery
    PPC Factory Main Program ***2015/5/10 ***
    #include "propeller.h"
    #include "stdio.h"
    #include "math.h"
    #include "stdlib.h"
    #include "adcDCpropab.h"
    void Help();
    void Set_Clock();
    int getdst();
    void Get_Time();
    void Get_Date();
    void Valves();
    void StartOps();
    void SetValve();
    int i;
    int j;
    int hour;
    int Selection;
    int AirValve;
    int Air;
    int Amount;
    int Water=8150;
    int Acid=500;
    int A=500;
    int B=500;
    int Base=500;
    int Valve;
    static volatile char *s;
    int main()
    uint8_t buffer[40];
    print("This is SoftRTC\n");
    while(1)
    print("> ");
    gets(buffer);
    if(!strcmp(buffer, "run")) break;
    else
    // while(1) ///Main Program Loop
    if(1 == 1)
    print("Hello.\n");
    Get_Time();
    print("Time is %c\n",s); //****Will not display timebuff from Get_Time()***
    Selection = 0;
    Valve = 1;
    Valves();
    //Subroutines//
    void Help()
    print("Commands are: setclock, time, date, run.\n");
    void Set_Clock()
    struct timeval tv;
    struct tm t;
    int getdst()
    int rc = 0;
    fflush(stdout);
    getchar();
    return rc;
    int rc = 0;
    char *endp;
    do
    print("Enter %: ",prompt);
    fflush(stdout);
    fflush(stdin);
    if(endp == buffer)
    if('\n' == *endp)
    rc = 0;
    break;
    return rc;
    void Get_Time()
    char timebuff[16];
    time_t now = 0;
    now = time(&now);
    s = timebuff;
    void Get_Date()
    char timebuff[16];
    time_t now = 0;
    now = time(&now);
    void ZeroBus()
    low(0); //Bus 0
    low(1); //Bus 1
    low(2); //Bus 2
    low(3); //Bus 3
    low(4); //Bus 4
    low(5); //Bus 5
    low(6); //Bus 6
    low(7); //Bus 7
    void DispenseRoutine()
    if(Selection == 0)
    AirValve = Air*Amount;
    if(Selection == 1)
    high(8); //Vent valve open
    pause (20000);
    high(9); //Acid Valve open
    for(j=1; j<Amount+1; j++)
    pause (Acid);
    low(9); //Acid valve closed
    pause (1000);
    high(10); //Water valve open
    for(j=1; j<Amount; j++)
    pause (Water);
    low(10); //Water valve closed
    pause (1000);
    if(Selection == 2)
    pause (20000);
    high(9); //Acid valve open
    pause (Acid);
    pause (1000);
    high(11); //Nutrient A valve open
    pause (A);
    low(11); //Nutrient A valve closed
    high(12); //Nutrient B valve open
    pause (B);
    low(12); //Nutrient B valve closed
    pause (1000);
    pause (Water);
    low(8); //Vent valve closed
    pause (1000);
    void VentTank()
    high(8); //Vent open
    pause (1000);
    low(8); //Vent closed
    pause (100);
    void Valves()
    for(i=1; i<255; i++)
    if(Valve == i) //Valve 1
    Amount = 1;
    A = 2500;
    B = 2500;
    Acid = 500;
    Base = 0;
    StartOps();
    if(Valve == i) //Valve 2
    Amount = 2;
    A = 2500;
    B = 2500;
    Acid = 500;
    Base = 0;
    StartOps();
    void StartOps()
    pause (2000);
    DispenseRoutine();
    SetValve();
    void SetValve()
    for(i=1; i<10; i++)
    if(i == 1)
    high(0); //Bus 0
    high(26);
    pause (2000);
    low(0);
    low(26);
    pause (2000);
    if(i == 2)
    high(1); //Bus 1
    high(27);
    pause (2000);
    low(1);
    low(27);
    pause (2000);
    if(i == 3)
    high(0);
    high(26);
    high(1);
    high(27);
    pause (2000);
    low(0);
    low(26);
    low(1);
    low(27);
    edited 2015-05-11 15:37
    You need to make timebuff static also. Currently it resides on the stack, and the stack area it uses will be overwritten when you return from Get_Time. If you make it static it will not be on the stack.
    edited 2015-05-11 16:05
    Okay, so timebuff should be
    static volatile *timebuff ?
    The original author uses timebuff in both the Get_Time and Get_Date functions...should they be different as in timebuffA and timeBuffB?
    Should the stack size be increased?
    Sincerely,
    Discovery
    edited 2015-05-11 18:00
    Hi Dave,
    I can now use the time of day in my main program.
    The changes are:
    static volatile char *timebuff[16];
    char timebuff[16]; was removed from the Get_Time function
    In the main program
    A call to Get_Time followed by
    s = timebuff;
    print("Time is %s\n",s);
    Works fine.
    Thank you Dave.
    Sincerely,
    Discovery
    edited 2015-05-12 05:08
    Glad to see you making progress, hopefully you will show your complete working program once you have all the kinks worked out.
    Ray
    edited 2015-05-12 08:06
    Well...not so fast!
    In the code below in the second would be WHILE loop, I am trying to compare the TIME character string from the SoftRTC to the T1 character string and it will not match.
    Ray and Dave...why not?
    Discovery
    #include "stdio.h"
    #include "math.h"
    #include "stdlib.h"
    void Help();
    void Set_Clock();
    int getdst();
    void Get_Time();
    void Get_Date();
    void Valves();
    void StartOps();
    void SetValve();
    int i;
    int j;
    int hour;
    int Selection;
    int AirValve;
    int Air;
    int Amount;
    int Water=8150;
    int Acid=500;
    int A=500;
    int B=500;
    int Base=500;
    int Valve;
    char U[] = "09:12:00";
    char V[] = "09:12:00";
    static volatile char *T1;
    int main()
    uint8_t buffer[40];
    while(1)
    print("> ");
    gets(buffer);
    else
    if(1 == 1)
    Get_Time();
    print("Time is %s\n",timebuff);//Works
    T1 = "09:54:00";
    s = timebuff;
    print("Time is %s\n",s);//Works
    if(!strcmp(T1,s)) //Fails comparison
    print("Match\n");
    high(26);
    high(27);
    else
    print("No Match\n");
    low(26);
    low(27);
    Selection = 0;
    Valve = 1;
    Valves();
    //Subroutines//
    void Help()
    void Set_Clock()
    struct timeval tv;
    struct tm t;
    int getdst()
    int rc = 0;
    fflush(stdout);
    getchar();
    return rc;
    int rc = 0;
    char *endp;
    do
    fflush(stdout);
    fflush(stdin);
    if(endp == buffer)
    if('\n' == *endp)
    rc = 0;
    break;
    return rc;
    void Get_Time()
    time_t now = 0;
    now = time(&now);
    void Get_Date()
    char timebuff[16];
    time_t now = 0;
    now = time(&now);
    void ZeroBus()
    low(0); //Bus 0
    low(1); //Bus 1
    low(2); //Bus 2
    low(3); //Bus 3
    low(4); //Bus 4
    low(5); //Bus 5
    low(6); //Bus 6
    low(7); //Bus 7
    if(Selection == 0)
    if(Selection == 1)
    pause (20000);
    pause (Acid);
    pause (1000);
    pause (Water);
    pause (1000);
    if(Selection == 2)
    pause (20000);
    pause (Acid);
    pause (1000);
    pause (A);
    pause (B);
    pause (1000);
    pause (Water);
    pause (1000);
    void VentTank()
    pause (1000);
    pause (100);
    void Valves()
    Amount = 1;
    A = 2500;
    B = 2500;
    Acid = 500;
    Base = 0;
    StartOps();
    Amount = 2;
    A = 2500;
    B = 2500;
    Acid = 500;
    Base = 0;
    StartOps();
    void StartOps()
    pause (2000);
    DispenseRoutine();
    SetValve();
    void SetValve()
    for(i=1; i<10; i++)
    if(i == 1)
    high(0); //Bus 0
    high(26);
    pause (2000);
    low(0);
    low(26);
    pause (2000);
    if(i == 2)
    high(1); //Bus 1
    high(27);
    pause (2000);
    low(1);
    low(27);
    pause (2000);
    if(i == 3)
    high(0);
    high(26);
    high(1);
    high(27);
    pause (2000);
    low(0);
    low(26);
    low(1);
    low(27);
    edited 2015-05-12 08:13
    edited 2015-05-12 08:21
    I believe you want a char array here, not a pointer array, IOW get rid of the star (although that wouldn't explain your comments).
    Also, when you post code please wrap it in [noparse]
    [/noparse] tags.
    edited 2015-05-12 08:39
    Please use [ CODE ] ... [ /CODE ], without the spaces to show your code. For the time being you may want to leave out all that other code, and just show the comparison code that you are trying to work out, all the non essential, at this point, is very distracting.
    I inserted some code, this is the way I would go about trying narrow down the problem.
    Ray
    [ CODE ]
    Get_Time();
      s=timebuff;
      T1="09:54:00";
     //T1 = "09:54:00";
     //s = timebuff;
      print("%s\n",T1);  // This to see what the value of T1 is
     print("Match\n");
     high(26);
     high(27);
     else
     low(26);
     low(27);
     Selection = 0;
     Valve = 1;
     Valves();
    [ /CODE ]
    edited 2015-05-12 09:13
    The print out to the screen for s is:
    09:54:00
    And the print out to the screen for T1 is:
    09:54:00
    They appear as identical on the print to screen but
    if(!strcmp(T1,s))
    fails the comparison.
    Discovery
    edited 2015-05-12 09:43
    I wonder if the s string has a NULL character at the end while the T1 string does not...or vise versa.
    Discovery
    edited 2015-05-12 11:05
    Discovery wrote: »
    Actually you're printing the same string twice (timebuf and s) but never T1. Maybe that:s the problem here. They look the same but the comparison is against something else altogether.
    edited 2015-05-12 11:36
    It looks like it should print timebuf, T1 and s. Can you post the output that you get from the program when you run it?
    edited 2015-05-12 13:51
    Look at the code carefully...
    1. Get_Time reads the RTC and dumps the value into timebuff.
    2. Timebuff is then copied into the global static variable s.
    3. A start time character string is generated as a line of code and placed into T1.
    4. I print out T1 and s to compare the values on the screen.
    5. The values look identical on the screen.
    6. The two strings, T1 and s are compared with !strcmp and fail to match.
    The output is:
    > setclock
    Use daylight savings time [y/n] ? y
    Enter 2015
    Enter 5
    Enter 12
    Enter 9
    Enter 53
    Enter 50
    > time
    09:53:52
    > run
    09:53:59
    Time is 09:53:59
    Time is 09:54:00
    Time is 09:53:59
    No Match
    Oh...
    I set the start time to 09:54:00 then set the clock time to 09:53:50...checked the time and pressed run. It appears that it would be just plane luck if the clock time was 09:54:00 when the comparison was made.
    I must put the Get_Time and comparison lines in a WHILE loop to insure that !strcmp catches the RTC at 09:54:00.
    Dave...would you agree?
    Discovery
