How to use SpinWrap on Windows, any executable available?
banjo
So I was going to try SpinWrap on the PropCam Spin code. Found it on GitHub but have not been able to successfully compile spinwrap.c. I've tried with three different compilers (MS Visual C++ 2010, Borland C++ Builder, SimpleIde) but they all error out on different things which is bound to take some time to resolve with my limited experience.
Is there any SpinWrap executable available for Windows so I could skip the compiling?
David
spinwrap-win.zip
Will test more after a couple of hours when I'm home.
Thomas
Let me know if you have any trouble with it. You'll also need to have OpenSpin installed to use spinwrap.
I downloaded OpenSpin as well. So am I correct in that I need to use OpenSpin instead of SimpleIde to compile? If so, how do I transfer it to the Propeller Activity Board?
