Help using AC power Ultrasonic Transducer
Hello I am hoping that someone could help me with a project I am working on. I am trying to make a homemade ultrasonic cleaning device. What I am going for is something like this link here.
http://www.instructables.com/id/Home-Made-Ultrasonic-Cleaning-Tank/
This is my first project ever working with AC power and I am nervous about it. Working with a stamp and 5v battery not a huge deal if you mess up. Different story if using 110v. So what I am concerned about is connecting my generator to the power supply. I have attached a picture of my generator with some very basic instructions.
So my question is do I just take a power cord, cut it, splice it, solder it to the connections and plug into wall once all connections have been made? It just says AC so I am assuming there is no positive or negative. Also once this thing is connected how dangerous is this generator? Meaning if I touch certain parts of it am I going to get a real shock?
Thanks for looking at and helping a newbie to 110v. I might be overly cautions but it frightens me.
From the picture it looks like the generator has a line fuse to protect itself (somewhat) . Attach the AC power cord per the instructions making sure all the strands in each conductor are lightly twisted together and properly tinned to prevent a stray strand from shorting things out. But before plugging it in observe all the precautions in the DIY article and enclose the generator in a non-metallic fireproof, well ventilated enclosure. You may want to enlist the help of a friend that might be a little more comfortable around line voltages.
would you suggest any electrical tape or other item to place over the connection where i solder or is that not necessary.
Thanks for replying
It's not really needed if the power supply is in an enclosure, but placing electrical tape or some other form of shielding over the AC and transducer connections is a good idea.
