propgcc now in the Parallax github - Page 9 — Parallax Forums
1567911
  • DavidZemonDavidZemon Posts: 2,973
    edited 2015-04-18 06:37
    That would be very cool. Unfortunately, I don't have access to the physical server. We would need propeller-load to work over an ssh tunnel.
    I do have a raspberry pi here though.... I suppose I could copy the files from the build server to the pi and then run the tests. That'd sure be interesting. Or at that point, actually I could install a build agent on the pi and have libpropeller only run from that build agent.
  • David BetzDavid Betz Posts: 14,521
    edited 2015-04-19 08:57
    I just tried a clean install of Ubuntu 14.04 and am having trouble building the obsolete version of texinfo that is needed for propgcc builds. Does anyone have a solution to this? I followed the instructions on the Google Code Wiki but texinfo-4.13 won't build on my system.
    terminal.o:/home/dbetz/texinfo-4.13/info/terminal.c:585: more undefined references to `tgetstr' follow
    terminal.o: In function `terminal_initialize_terminal':
    /home/dbetz/texinfo-4.13/info/terminal.c:617: undefined reference to `tgetflag'
    /home/dbetz/texinfo-4.13/info/terminal.c:620: undefined reference to `tgetstr'
    /home/dbetz/texinfo-4.13/info/terminal.c:628: undefined reference to `tgetstr'
    /home/dbetz/texinfo-4.13/info/terminal.c:629: undefined reference to `tgetstr'
    /home/dbetz/texinfo-4.13/info/terminal.c:630: undefined reference to `tgetstr'
    /home/dbetz/texinfo-4.13/info/terminal.c:631: undefined reference to `tgetstr'
    terminal.o:/home/dbetz/texinfo-4.13/info/terminal.c:633: more undefined references to `tgetstr' follow
    terminal.o: In function `terminal_begin_using_terminal':
    /home/dbetz/texinfo-4.13/info/terminal.c:135: undefined reference to `tputs'
    /home/dbetz/texinfo-4.13/info/terminal.c:144: undefined reference to `tputs'
    terminal.o: In function `terminal_end_using_terminal':
    /home/dbetz/texinfo-4.13/info/terminal.c:166: undefined reference to `tputs'
    /home/dbetz/texinfo-4.13/info/terminal.c:175: undefined reference to `tputs'
    terminal.o: In function `terminal_goto_xy':
    /home/dbetz/texinfo-4.13/info/terminal.c:235: undefined reference to `tputs'
    terminal.o:/home/dbetz/texinfo-4.13/info/terminal.c:272: more undefined references to `tputs' follow
    collect2: error: ld returned 1 exit status
    edited 2015-04-19 14:17
    Looks like those are curses dependencies. Do you have curses installed?
    edited 2015-04-19 18:29
    That's what I thought and I tried installing libncurses5-dev but that didn't help.
    edited 2015-04-27 20:09
    Well this is new :/
    Linking C executable fatfilereader_test
    /opt/parallax.2408/propeller-elf/lib/libc.a(malloc.o): In function `__common_malloc':
    (.text+0x24): undefined reference to `__LMM_MVI_r2'
    (.text+0xb4): undefined reference to `__LMM_MVI_r6'
    (.text+0xd0): undefined reference to `__LMM_MVI_r6'
    /opt/parallax.2408/propeller-elf/lib/libc.a(malloc.o): In function `__hubmalloc':
    (.text+0xfc): undefined reference to `__LMM_MVI_r0'
    /opt/parallax.2408/propeller-elf/lib/libc.a(malloc.o): In function `__hubfree':
    (.text+0x10c): undefined reference to `__LMM_FCACHE_LOAD'
    /opt/parallax.2408/propeller-elf/lib/libc.a(rand.o): In function `_rand':
    (.text+0x18): undefined reference to `__LMM_MVI_r1'
    (.text+0x20): undefined reference to `__LMM_MVI_r6'
    /opt/parallax.2408/propeller-elf/lib/libc.a(toupper.o): In function `_toupper':
    (.text+0x8): undefined reference to `__LMM_MVI_r7'
    /opt/parallax.2408/propeller-elf/lib/libc.a(sbrk.o): In function `__sbrk':
    (.text+0x4): undefined reference to `__LMM_MVI_r6'
    (.text+0x10): undefined reference to `__LMM_MVI_r7'
    (.text+0x3c): undefined reference to `__LMM_MVI_r5'
    (.text+0x5c): undefined reference to `__LMM_MVI_r6'
    /opt/parallax.2408/propeller-elf/lib/libc.a(memcpy.o): In function `_memcpy':
    (.text+0x34): undefined reference to `__LMM_FCACHE_LOAD'
    /opt/parallax.2408/propeller-elf/lib/libc.a(memset.o): In function `_memset':
    (.text+0x4c): undefined reference to `__LMM_FCACHE_LOAD'
    (.text+0x88): undefined reference to `__LMM_FCACHE_LOAD'
    /opt/parallax.2408/propeller-elf/lib/libc.a(strcmp.o): In function `_strcmp':
    (.text+0x0): undefined reference to `__LMM_FCACHE_LOAD'
    /opt/parallax.2408/propeller-elf/lib/libc.a(strcpy.o): In function `_strcpy':
    (.text+0x4): undefined reference to `__LMM_FCACHE_LOAD'
    /opt/parallax.2408/propeller-elf/lib/libc.a(strlen.o):(.text+0x8): more undefined references to `__LMM_FCACHE_LOAD' follow
    /opt/parallax.2408/lib/gcc/propeller-elf/4.6.1/libgcc.a(unwind-sjlj.o): In function `_Unwind_SjLj_SetContext':
    /home/steve/Projects/propgcc/gcc/libgcc/../gcc/unwind-sjlj.c:163: undefined reference to `__LMM_MVI_r9'
    /home/steve/Projects/propgcc/gcc/libgcc/../gcc/unwind-sjlj.c:163: undefined reference to `__LMM_MVI_r6'
    /opt/parallax.2408/lib/gcc/propeller-elf/4.6.1/libgcc.a(unwind-sjlj.o): In function `_Unwind_SjLj_Register':
    /home/steve/Projects/propgcc/gcc/libgcc/../gcc/unwind-sjlj.c:134: undefined reference to `__LMM_MVI_r7'
    /home/steve/Projects/propgcc/gcc/libgcc/../gcc/unwind-sjlj.c:163: undefined reference to `__LMM_MVI_r7'
    /opt/parallax.2408/lib/gcc/propeller-elf/4.6.1/libgcc.a(unwind-sjlj.o): In function `_Unwind_SjLj_GetContext':
    /home/steve/Projects/propgcc/gcc/libgcc/../gcc/unwind-sjlj.c:149: undefined reference to `__LMM_MVI_r7'
    /opt/parallax.2408/lib/gcc/propeller-elf/4.6.1/libgcc.a(unwind-sjlj.o): In function `_Unwind_SjLj_ForcedUnwind':
    /home/steve/Projects/propgcc/gcc/libgcc/../gcc/unwind.inc:202: undefined reference to `__LMM_MVI_r7'
    /opt/parallax.2408/lib/gcc/propeller-elf/4.6.1/libgcc.a(unwind-sjlj.o): In function `_Unwind_SjLj_Resume':
    /home/steve/Projects/propgcc/gcc/libgcc/../gcc/unwind.inc:225: undefined reference to `__LMM_MVI_r7'
    /opt/parallax.2408/lib/gcc/propeller-elf/4.6.1/libgcc.a(unwind-sjlj.o):/home/steve/Projects/propgcc/gcc/libgcc/../gcc/unwind.inc:255: more undefined references to `__LMM_MVI_r7' follow
    collect2: ld returned 1 exit status
    PropWare/tests/CMakeFiles/fatfilereader_test.dir/build.make:88: recipe for target 'PropWare/tests/fatfilereader_test' failed
    make[2]: *** [PropWare/tests/fatfilereader_test] Error 1
    CMakeFiles/Makefile2:1064: recipe for target 'PropWare/tests/CMakeFiles/fatfilereader_test.dir/all' failed
    make[1]: *** [PropWare/tests/CMakeFiles/fatfilereader_test.dir/all] Error 2
    Makefile:137: recipe for target 'all' failed
    make: *** [all] Error 2
    Running from build 2408. I'll check tomorrow with a more up-to-date version
    edited 2015-04-28 02:26
    Looks like it's not linking in the LMM kernel. Can you post the entire program and the commands you're using to build it?
    edited 2015-04-28 04:29
    It's building PropWare. Since it still builds in teamcity I doubt it will be easily reproducible. This is the first build that I've run on Ubuntu 15.04 though.
    edited 2015-04-28 05:27
    Can you post the build log including the command lines?
    edited 2015-04-28 06:29
    soon as i get home tonight, yea
    edited 2015-04-28 07:47
    Actually, I guess I can log into TeamCity and get it myself, right?
    edited 2015-04-28 08:10
    I should have clarrified, I'm getting this error only on my local machine. TeamCity is still building correctly with the latest build of PropGCC4.
    edited 2015-04-28 15:35
    Ah, turns it out it wasn't a problem in the first place. I had an existing build directory and didn't think to clean it out before attempting to build from the new OS. Once I cleared the build directory and rebuilt, it was fine.
    It is interesting that Steve's name and his personal build directory shows up in the debug output though...
  • jazzedjazzed Posts: 11,803
    edited 2015-04-29 08:00
    David Betz wrote: »
    Hi
    These links from post 1 don't work for me with wget.
    Amazingly the gcc4 Win32 link from post 237 seems to work.
    edited 2015-04-29 08:56
    @David Betz,
    Looks like when you copied/pasted the contents, you copied and pasted the ellipsis too, instead of the full URLs.
    edited 2015-04-29 09:51
    @David Betz,
    I just copied it from your message and pasted it into the top post. Can you send me the real URLs?
    edited 2015-04-29 17:56
    Here ya go
    [noparse]GCC4
    [url=http://david.zemon.name:8111/repository/download/PropGCC5_Gcc4linuxX64/.lastSuccessful/propellergcc-alpha_v1_9_0-gcc4-linux-x64.tar.gz?guest=1]x86-64 Linux[/url]
    [url=http://david.zemon.name:8111/repository/download/PropGCC5_Gcc4rpi/.lastSuccessful/propellergcc-alpha_v1_9_0-gcc4-rpi.tar.gz?guest=1]RPi[/url]
    [url=http://david.zemon.name:8111/repository/download/PropGCC5_Gcc4win32/.lastSuccessful/propellergcc-alpha_v1_9_0-gcc4-win32.zip?guest=1]Win32[/url]
    GCC5
    [url=http://david.zemon.name:8111/repository/download/PropGCC5_Gcc5linuxX64/.lastSuccessful/propellergcc-alpha_v1_9_0-gcc5-linux-x64.tar.gz?guest=1]x86-64 Linux[/url]
    [url=http://david.zemon.name:8111/repository/download/PropGCC5_Gcc5rpi/.lastSuccessful/propellergcc-alpha_v1_9_0-gcc5-rpi.tar.gz?guest=1]RPi[/url]
    [url=http://david.zemon.name:8111/repository/download/PropGCC5_Gcc5win32/.lastSuccessful/propellergcc-alpha_v1_9_0-gcc5-win32.zip?guest=1]Win32[/url][/noparse]
  • SRLMSRLM Posts: 5,045
    edited 2015-04-29 18:16
    You could also use the [noparse][noparse][/noparse] tag. eg
    [noparse]
    GCC4
    x86-64 Linux
    RPi
    Win32
    GCC5
    x86-64 Linux
    RPi
    Win32
    [/noparse]
    edited 2015-04-29 19:41
    Thanks. I figured there had to be some way to do that
    edited 2015-04-29 19:46
    SRLM wrote: »
    [noparse]
    GCC4
    x86-64 Linux
    RPi
    Win32
    GCC5
    x86-64 Linux
    RPi
    Win32
    [/noparse]
    Thanks! I just updated the top post with those links.
    edited 2015-06-28 20:18
    the TeamCity build has been busted for a while now and I finally have a hint as to why. spin2cpp has been downloaded into a out-of-source directory. I'm guessing this is something weird and specific to TeamCity, not the git or build configuration, but wanted to check with you all first. Here's a snippet from the log:
    [22:00:30] :	 [Step 3/6] make[1]: Leaving directory `/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/71b5f7d6548ebb35/openspin'
    [22:00:30] :	 [Step 3/6] Installing openspin
    [22:00:30] :	 [Step 3/6] Building spin2cpp
    [22:00:30] :	 [Step 3/6] make[1]: Entering directory `/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/71b5f7d6548ebb35/spin2cpp'
    [22:00:30] :	 [Step 3/6] mkdir -p /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp
    [22:00:30] :	 [Step 3/6] bison -t -b /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp/spin -d spin.y
    [22:00:30] :	 [Step 3/6] gcc -g -Wall -Werror -I. -I/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp -o /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp/symbol.o -c symbol.c
    [22:00:30] :	 [Step 3/6] gcc -g -Wall -Werror -I. -I/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp -o /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp/ast.o -c ast.c
    [22:00:30] :	 [Step 3/6] gcc -g -Wall -Werror -I. -I/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp -o /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp/expr.o -c expr.c
    [22:00:30] :	 [Step 3/6] gcc -g -Wall -Werror -I. -I/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp -o /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp/flexbuf.o -c flexbuf.c
    [22:00:30] :	 [Step 3/6] gcc -g -Wall -Werror -I. -I/var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp -o /var/www/vhosts/david.zemon.name/TeamCity/buildAgent/work/propeller-gcc4-build/spin2cpp/preprocess.o -c preprocess.c
    [22:00:30]W:	 [Step 3/6] In file included from spinc.h:19:0,
    [22:00:30]W:	 [Step 3/6]                  from ast.c:7:
    [22:00:30]W:	 [Step 3/6] lexer.h:6:22: fatal error: spin.tab.h: No such file or directory
    [22:00:30]W:	 [Step 3/6]  #include "spin.tab.h"
    [22:00:30]W:	 [Step 3/6]                       ^
    [22:00:30]W:	 [Step 3/6] compilation terminated.
    Specifically, I would not expect the directory from line 4 to be different from line 5.
  • The spin.tab.h issue was related to parallel jobs. The makefile looks solid to me, so I'm not sure why too many concurrent jobs had it failing, but removing the -j option entirely has fixed it. Builds take 30 minutes now, but I guess that's better than failing 100% of the time.
    Cross compiling no longer works. The build relies on libexpat which isn't readily available as a Windows or ARM lib. Is the library really needed, or was its inclusion an accident? If needed, how can I make it visible to the system?
  • What relies on libexpat? Is it spin2cpp? Maybe Eric can answer that.
  • I've found the dependency issue in spin2cpp that caused the build to fail with parallel jobs. Issue report created: https://github.com/totalspectrum/spin2cpp/issues/3
  • FastrobotFastrobot Posts: 51
    edited 2015-10-13 01:35
    gdb needs a curses package to do terminal formatting. ncurses is the standard (highly desired) package on most linux systems. It shouldn't be part of the source code package, because it's a shared library dependency that is expected to be supplied by the OS.
    Usually, pkg-config, should be able to find a working/installed version of either curses or ncurses on your system when a gnu ./configure script is run. If it can't then sometimes broken make scripts do things like you are seeing.
  • David Betz wrote: »
    This is still an issue :(
  • TorTor Posts: 2,010
    libexpat is an XML parser library, is XML parsing a part of this?
  • Fastrobot wrote: »
    We provide ncurses sources because some cross-compilers (particularly those targeting the Raspberry Pi) do not have curses libraries available. It's not a problem for native builds, so if you don't ever want to cross compile then you don't need to worry about it.
    spin2cpp certainly doesn't need libexpat. I think gdb is the only part of the propgcc system that needs it -- gdb uses xml for some configuration files for embedded systems. If you skip building gdb then you can probably avoid expat.
  • ersmith wrote: »
    David Betz wrote: »
    Good to know, but we don't want to skip building GDB do we?
  • Builds from my build server don't include the tweak/patch version in the version string. For instance, the --version output gives:
    dzweb@davidzemonname:~$ propgcc4-bin/bin/propeller-elf-gcc --version
    propeller-elf-gcc (propellergcc-alpha_v1_9_0_) 4.6.1
    Copyright (C) 2011 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions.  There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    That's no good! :(
    Anyone mind pointing me in the right direction for getting that added to the build?
